Advanced Member Britain Posted August 8 Advanced Member Share Posted August 8 (edited) 3dcoat 2024 25 Reset to default: This doesn't appear to be working. Not working in edit or in the preference section or smart materials. I had to uninstall completely and install to get back to default. Opening 3dcoat should be a default setting not where you left off. Found this when changing retopo values. The good side of the new install 2024 25 the sizing in the 3dcoat app to Blender appears to be working for now as long as the apply scale is checked. Hope it stays that way. Seems to be slight font size change on the program. I had to size down to get the open in external app to be viewed in it entirety. Edited August 8 by Britain 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 8 Share Posted August 8 Are you running 3DC with Administrator privilege's ? Quote Link to comment Share on other sites More sharing options...
Advanced Member Britain Posted August 8 Author Advanced Member Share Posted August 8 1 hour ago, Carlosan said: Are you running 3DC with Administrator privilege's ? Iam. I did the tutorial on restoring windows once you have moved them about. The restore doesn't restore them back to default either. The only item that will restore is when I change the font larger so that I can read items on a high res monitor ( preferences). On preferences under general what is Restore Windows State? The document you wrote left that blank. It looks like pathways are broke somewhere on reset for me anyway. I remember you use to delete the option.xml file to reset but i cant find that. Is there another way to restore defaults? Ive already made a backup file on the smart materials just incase. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 8 Share Posted August 8 You mean this ? I remembered a Rygaard's video about that settings, hope this help Quote Link to comment Share on other sites More sharing options...
Advanced Member Britain Posted August 8 Author Advanced Member Share Posted August 8 (edited) I'm not so concern about the workspace layout. Thanks for the vid. Ill do a back up on the workspace. Edit: ok you need to go to the Windows drop down and Reset this page to default or all pages to default this works for window workspace. Not sure why in preference it isn't working or I misunderstand how this area works. When doing changes, closing the program then opening keeps the previous changes. IS this how it works? If so being able to reset those values to default is important, at least for me. Edited August 8 by Britain 1 Quote Link to comment Share on other sites More sharing options...
