Transparent Fur & Render View
JPWestmas
Posted (edited)
So the transparent fur object (flyaway hairs) renders correctly over the geometry beneath it in the side view. But not in the front view. In the front view the transparency renders through all objects layers. Layer 0 visibility is off of course. Is there some sort of camera viewport clipping for transparency, Is that adjustable?
Edited by JPWestmas
  • 2 weeks later...
Nope doesn't help the transparency cutting through. I think you're right that it is a render order thing. That's what it is in unity, I have to change the rendering order priority. Doesn't appear that 3Dcoat has that exactly right. Or is broken.
Edited by JPWestmas
  • Confused 1
23 minutes ago, Carlosan said:
When you import that textures on other external app, are rendering ok ?
Yeah, can get it to work fine in URP unity 2021. The alpha can be made to work by default using the transparency model for the  URP standard shader. With some shader graphs that require a black and white alpha mask, it sometimes takes some priority slider tweaking.
