  • 0
3dcoat merge selected issue
muomuoaabb
Question
Im a 3dcoat beginner.I really confuse how 3dcoat merge sculpt obj.I was using H and shift H to select obj that I want to merge ,and then I click merge select ,sometimes It do what I expect(merge the selection)But sometimes the selection merge to something that wasnt being selected?when this issue happened I try to ctrl+z undo sometimes it work but sometimes the selected mesh just disappear!?Then I have to shut down the software and open therecover file...
This issue really confuse me.Ididnt find any patten. what did I do wrong?
2 answers to this question
  • 0
This can happen if you have a complex Sculpt Tree structure.
Regarding the error with ctrl +z, a quick test did not reveal the problem. Perhaps the error is in your specific scene. You can share the scene and then I will test it.
  • 0
Yes there are too many sculpt obj,,the original file is also too big about 800mb,which is not allowed to upload,I think the ctrl +Z issue probably also related to the complex sculpt tree.Next time I really should reduce the complexity.thank you so much!Really learn alot!
Answer this question...
