How do I smooth visible topology only and protect hard edges from smoothing?
Hello all.
I am retopologising the upper half of a character.
It has a jacket that was modelled separately but is included so that I generate a single piece of geometry.
This means that I am creating geometry away from the model at times. You can see a false 'base' on the screen grab attached.
When smoothing the geometry I want to avoid it smoothing the lapel and hem of the jacket - is there a way of doing this?
Also can I smooth visible areas only. At the moment when I smooth the outside of the jacket it smooths areas on the inner side, that I don't want to snap to the model (eg the base').
Any help would be much appreciated.
Carlosan
Grakino was awarded the badge 'Helpful' and 1 points.
@Jakejazz
Choose select, edge mode. Select edges you don't want to smooth. In "Selected" section click on "Mark as Sharp" button. The "Clear Sharp" cancel sharp. About visible area only i don't know, never try.
There might be situation when you apply sharp but nothing happen, in this case just rotate you camera a little bit to refresh you screen.
image.thumb.png.03a5c79bd22ddcb32bbd2cbb5a5663e8.pngimage.thumb.png.f57931bd152b2a1c3a7083a7c75e1f1b.pngimage.png.58dfb5f325d4c801866673ba21a7daf5.pngimage.thumb.png.6c2cfcfe07e6b5608afccd279d05b138.pngimage.png.7ea1d8f7438e28f85c83441925a54cf3.png
Edited by Grakino
