Hi, could you help me to understand how to deactivate the surface-based tool:
When i click on pose tool i have this message : " The volume has hidden parts and you activated the surface-based tool, Surface tools change the volume structure so essentially after the unhide the thin edge between the hidden and visible areas may appear"
When i have this message there is weird extrusion, if i moove something with the pose tool and valid the transform, voxel exploding like hole in the mesh.
it's ok on a fresh new scene, but on a scene that works perfeclty yesterday, now i can't use pose tool, i tried to delete tool settings in the install file, reset preferences by default, nothing change my problem
Thanks
When i do ctrl+z  "it's ok" but if i do another pose change the holes appear again, on the video i used scale but in case with translation it's the same
+ another pb when i scale it turn in weird angle instead to go inside straight
I also tried with 2023 version, same, the problem is a setting saved in the scene
Thanks
This message means that your sculpture has hidden parts. You can see the hidden parts in the Geometry tab -> Unhide All
thank you,
It works fine yesterday with the exact same operation, even if i unhide all it appears the same problem, and never had problem switching between vox hide and pose tool, also weird thing is first image showing ok when i do ctrl+z, thickness is ok
What is : the surface-based tool
But i work in voxel ? not in surface
i did'nt had this warning message before this morning, ihave the problem  even if i load old scene that should work
I thought it was backface culling to deactivate ... cause it work fine during 5min, i open another scene version do the same but now i can't even use the selection tool in pose mode it select nothing, mega bug :/
