Wrong rotation when importing to coat and back (how I solved it)
Grian Talamonti
  • New Member
Carlosan
Grian Talamonti was awarded the badge 'Great Content' and 1 points.
Im using blender 4.2 and coat 2024.26
when I send a 'mesh as sculpt object' from blender I see it rotated 90 degrees in coat
first I deleted the old addon in the addons_core (not the usual addon folder but the one in program files) and updated with the latest applink from github
then I changed the axis in the init.py everywhere it says 'export' to  axis_forward='-X', axis_up='Z'
now the object imports correctly into coat
the problem is that once you bring it back is rotated
so before bringing it back I have to deactivate z-up coordinate in the preferences of coat (which keeps toggling on everytime I send from blender)
bring it back and is in correct rotation
please test and fix
thank you
  • 2 weeks later...
Hi
You can change it on Edit > preferences
  • 3 weeks later...
  • New Member
There's still a possible issue with these OS and software version:
3DCoat 2024.29-04
Windows 11 23H2 (22631.4391)
In Blender > Export Mesh As Sculpt Object
And in Coat, when configured Y up, viewport gizmo auto change to Z up, but the imported object is still Y up.
If Coat is configured with Z up, the object still imports as Y up.
Is it a bug? Or is it configuration? Please help
