Member pedro8999 Posted October 11, 2024 Member Share Posted October 11, 2024 Hi ! I did retopo via decimation, then bake normal per pixel, then calculate curvature and occlusion. After that i can see some Artifacts glitches in the mesh. I am attaching all settings i used and also the issue. Please help Thanks Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 11, 2024 Share Posted October 11, 2024 What if you turn off Normalmap and AO layers ? Quote Link to comment Share on other sites More sharing options...
Member pedro8999 Posted October 11, 2024 Author Member Share Posted October 11, 2024 4 minutes ago, Carlosan said: What if you turn off Normalmap and AO layers ? The issue still there after i turn off those. When i did the retopo some layers had the symmetry on, not sure if that would be a problem Quote Link to comment Share on other sites More sharing options...
Member pedro8999 Posted October 11, 2024 Author Member Share Posted October 11, 2024 11 minutes ago, pedro8999 said: The issue still there after i turn off those. When i did the retopo some layers had the symmetry on, not sure if that would be a problem I just retopo again will all layers without symmetry and still the mesh looks like that Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 11, 2024 Share Posted October 11, 2024 Maybe the mesh have lower resolution ? Share a pic of the voxel mesh on same display postiton or share the mesh to take a look Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted October 11, 2024 Advanced Member Share Posted October 11, 2024 3 hours ago, pedro8999 said: I just retopo again will all layers without symmetry and still the mesh looks like that you have alot of triangles in your topology? for example is the a decimation? if so 3dcoat has trouble baking that , substance painter can and marmoset Quote Link to comment Share on other sites More sharing options...
New Member SawyerRussell Posted October 17, 2024 New Member Share Posted October 17, 2024 How is everything going, is it solved? Because, I also facing similar problem. Quote Link to comment Share on other sites More sharing options...
Member pedro8999 Posted October 17, 2024 Author Member Share Posted October 17, 2024 On 10/11/2024 at 7:20 PM, Elemeno said: you have alot of triangles in your topology? for example is the a decimation? if so 3dcoat has trouble baking that , substance painter can and marmoset I found that the problem comes from the voxel sculpt model, many things were not smooth enough, so after doing the retopo it still looks glitchy, i went back and i start either smoothing many layers or adding resolution and then smoothing, then retopo again and that fixed the issue! Thanks Quote Link to comment Share on other sites More sharing options...
Member pedro8999 Posted October 17, 2024 Author Member Share Posted October 17, 2024 11 hours ago, SawyerRussell said: How is everything going, is it solved? Because, I also facing similar problem. I found that the problem comes from the voxel sculpt model, many things were not smooth enough, so after doing the retopo it still looks glitchy, i went back and i start either smoothing many layers or adding resolution and then smoothing, then retopo again and that fixed the issue! Thanks Quote Link to comment Share on other sites More sharing options...
Member Solution pedro8999 Posted October 17, 2024 Author Member Solution Share Posted October 17, 2024 On 10/11/2024 at 5:00 PM, Carlosan said: Maybe the mesh have lower resolution ? Share a pic of the voxel mesh on same display postiton or share the mesh to take a look Yes that was the problem! I found that the problem comes from the voxel sculpt model, many things were not smooth enough, so after doing the retopo it still looks glitchy, i went back and i start either smoothing many layers or adding resolution and then smoothing, then retopo again and that fixed the issue! Thanks 1 Quote Link to comment Share on other sites More sharing options...
