Advanced Member geo_n Posted October 15, 2024 Advanced Member Share Posted October 15, 2024 I'm trying out the vdm pick and paste. Can the capture depth be adjusted so it won't capture the back and turn it into a cylinder? Because when I use extrude the cylinder gets stamped on the other models. And when I use extrude on the same layer the vdm is not as detailed as the original. VDM size was 1024. Is there a way to improve it? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 15, 2024 Share Posted October 15, 2024 Hi Try this hint Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted October 15, 2024 Author Advanced Member Share Posted October 15, 2024 40 minutes ago, Carlosan said: Hi Try this hint For surface mode right? How about for voxel mode? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 15, 2024 Share Posted October 15, 2024 currently vdm brushes works on surface mode Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted October 16, 2024 Author Advanced Member Share Posted October 16, 2024 13 hours ago, Carlosan said: currently vdm brushes works on surface mode Ah thanks. Wierd it worked on voxel as you can see in the pic. But quality was not so detailed. How do people control how deep the capture of the vdm will be? Or vice versa how do people control how deep the stamp well be to exclude the background cylinder? Quote Link to comment Share on other sites More sharing options...
Advanced Member JimB Posted Friday at 11:20 AM Advanced Member Share Posted Friday at 11:20 AM (edited) Can some one please tell me where Pick&Paste is in 3DCoat 2024.31 ? Nevermind its under KitBash. Edited Friday at 11:37 AM by JimB Quote Link to comment Share on other sites More sharing options...
Carlosan Posted Friday at 12:57 PM Share Posted Friday at 12:57 PM Also it is on Sculpt Room > Surface Mode Quote Link to comment Share on other sites More sharing options...
Advanced Member JimB Posted Friday at 03:03 PM Advanced Member Share Posted Friday at 03:03 PM Carlosan how did you get that menu up? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted Friday at 04:33 PM Share Posted Friday at 04:33 PM If you select Surface Sculpting Or Your Sculpt mesh is on Surface mode (S) letter left to the layer name. (V) is for Voxel mode The Pick & Paste Tool in the Surface Category on Left Tool Panel is available Also can press SpaceBar to show QuickAccess Panel Quote Link to comment Share on other sites More sharing options...
