  • 1
Material/Stencil Control Panel - Scale the material/stencil + Fracture Workflow
Laticis
Question
Hi,
Is there a way to set or is there a recommended workflow regarding setting material scale?
Example. Lets say I create a smart concrete/rock material and I want to make sure that material is filled at the same scale across 10 different sized meshes.
As a secondary question, what's is the recommend workflow for importing a High Poly Non UV'd Mesh into 3D Coat for texturing with Fracture?
I'm really looking for a way to create high res textures to bake them down to Low Poly UV'd meshes.
Side note: During some past test, I found exporting textures from 3DCoat and then modifying in Photoshop then re-importing the diffuse map caused additiional compression and a loss in original quality.
Cheers Ady
9 answers to this question
  • 0
4 minutes ago, Oleg Shapov said:
Hello! What data format are we talking about?
Hi Oleg,
Please forgive but I'm not quite sure I understand the question.
Ideally, I'd like to import an OBJ or FBX ( I generally work with OBJ files ) - either Tris or Quads ( Tri would be great because I could decimate the mesh )
That being said open to any suggestions.
  • 0
For this test, I imported the HD Mesh for Vertex Painting, moved to the Fracture Page and then applied a shader. ( no texturing for some reason everything was painting white )
Imported the Retopo Mesh and then baked it, then continued layer texturing in the Painting Room.
Oh, the Blue Render is a Displacement map I created in ZBrush.
Edited by Laticis
  • 0
2 minutes ago, Oleg Shapov said:
Or maybe load the mesh for pixel painting and then bake it in Sculpt-mesh?
That's also interesting.
That's the thing with 3DCoat so many ways and possible workflows to get things done.
Answer this question...
