Carlosan Posted November 23, 2024 Share Posted November 23, 2024 author site - Vexod14: An atlas painted on 3DCoat. Always fun to color things on this gem TextureAtlas.mp4 - Vexod14: Experimenting with handpainting normalmap in Coat. I wish I tested this earlier. It's so cool !! - 45cend: Hey there! Looks cool! Are you achieving this by color sampling the normal colours or there is something else? - Vexod14: I modeled that "as normalmap" (just lighting a viewport with appropriate directional lights) Then I made a few models to get a picking normal image and used that in 3DCoat color picker to paint over the normalmap layer. the image itself (tga attached): (here's a jpeg preview but rather use the TGA above as it's a non-compressed image, you'll have better pixel values) The goal is to have most common angles to handpaint maps or alter baked ones In 3DCoat just make sure : - NormalMap layer is editable (or that you're using normalmap blend mode on your current layer) - color pick tool doesn't pick from all layers, else you won't be able to pick the normal map values and it's very useful to edit local values instead of guess-picking them on the image - paint mode is not using opacity, only pressure. Seems odd but you'll find that when painting normals you often get great results with a bold stroke instead of hundreds little touches. But that's a personal taste, you can still get great results with opacity turned on NormalMapPicker.tga 1 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Vexod14 Posted November 23, 2024 Advanced Member Share Posted November 23, 2024 (edited) Thanks @Carlosan for taking the time to share it here, hope this will help more users getting into handpainted normals in 3DCoat as a way to further break the "3D feel" in our medium. Please note that you can also learn on this technique by watching artists who work(ed) on Wayfinder/overwatch, I started to dig this technique after seeing multiple posts from Romain Durand on Twitter/X (https://www.romaindurand.com), he's not alone but probably the one who shared the most hints on it. What's here should give you a solid starter pack to tackle these maps in 3DCoat Edited March 17 by Vexod14 1 Quote Link to comment Share on other sites More sharing options...
