  • 1
Stencil + vertex lasso unpredictable results
AlexSD
Question
If i try to use regular brush + stencil - it works as expected.
But if i try to use vertex/box/rect. lasso, for some reason it creates unwanted "-" depth:
Im not even sure why its happen? Can i avoid such behaviour?
3 answers to this question
  • 0
Sculpt Layers only works on Surface mode.
Stencil resolution, model polygon density, models scale, brush parameters, stencil projection type, tool depth...
There is some variables to take present.
Try using another tool, like Vox Buildup like example.
  • 0
Its debenitely not the issue with brush. I try a few of them.
The problem is that all lasso will for some reason push depth above the surface:
Heres result of sphere in Surface mode. In both cases i use brush - Absolute.
Draw brush will produce the same result.
Answer this question...
