New Member Fimbulwinter Posted November 26, 2024 New Member Share Posted November 26, 2024 I just downloaded 3D Coat and found it running with extremely low fps. I think my device will be sufficient. I have a RTX 3060, i7 12th generation laptop. I haven't had the slightest problem with any other program. But as I open 3D Coat, the FPS sees the maximum value of 21. Please help if you know how I can fix it. The program attracted my attention. I took Udemy courses and was just about to start when I saw this problem. It was a great disappointment. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 26, 2024 Share Posted November 26, 2024 Hi Check on Edit Menu > Preferences if Vertical Synchronization is turned OFF It limit FPS by the display VSync frequency. It helps to decrease the GPU load. Use Windows Menu > Panels > FPS_monitor to check current framerate Hope this help Quote Link to comment Share on other sites More sharing options...
New Member Fimbulwinter Posted November 26, 2024 Author New Member Share Posted November 26, 2024 11 dakika önce Carlosan şunları söyledi: Hi Check on Edit Menu > Preferences if Vertical Synchronization is turned OFF It limit FPS by the display VSync frequency. It helps to decrease the GPU load. Geçerli kare hızını kontrol etmek için Windows Menüsü > Paneller > FPS_monitor'u kullanın Umarım bu yardım Unfortunately it didn't get fixed. Do you know another way to fix it? I would be really happy if we could sort it out. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 26, 2024 Share Posted November 26, 2024 Did you install the latest version ? MyDocuments folder is placed on network drive? Should be on local drive. Graphic drivers on your computer are uptodate ? Do you have OneDrive or SkyDrive attached to whole MyDocuments? It may also be the source of problems. Sometimes if you delete the "3DCoat" folder in your /home/Documents folder, which 3DCoat automatically generates on initial run of the program, will solve some problems. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted November 29, 2024 Share Posted November 29, 2024 Please send me the log.txt in users/...user../Documents/3DCoat/log.txt to andrewashpagin@gmail.com Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted November 29, 2024 Reputable Contributor Share Posted November 29, 2024 On 11/26/2024 at 11:48 AM, Fimbulwinter said: I just downloaded 3D Coat and found it running with extremely low fps. I think my device will be sufficient. I have a RTX 3060, i7 12th generation laptop. I haven't had the slightest problem with any other program. But as I open 3D Coat, the FPS sees the maximum value of 21. Please help if you know how I can fix it. The program attracted my attention. I took Udemy courses and was just about to start when I saw this problem. It was a great disappointment. Is it using OneDrive in any capacity, because that is known to cause some issues? Anti-Virus apps can also interfere, so try to add 3DCoat to the Exceptions list of any Anti-Virus/Firewall software. Update any drivers you have, for your GPU, Wacom tablet, 3DConnexion devices, etc...because anyone of them could also create bug like/sluggish behavior. I have experienced all of these at various points....once in a blue moon...over the years. Doing those steps will help narrow things down if they don't solve the issue outright. It should not be responding this way, as I recently began upgrading my PC from an i9 10850K and GTX 1080Ti, and it was performing pretty well. So, it's just a matter of finding out what is causing the issue. If you are overclocking, make sure to run some stability tests. If you can run Cinebench as an example, it really stresses the CPU & Memory, and if that doesn't result in crashes/instability, then it should be okay to use 3DCoat on a regular basis. Quote Link to comment Share on other sites More sharing options...
