Can't paint over certain parts of my model, even though they are on the udim
Miha G
All the uvislands are on the first quadrant ?
All UV coordinates should be in the range 0.0 to 1.0 and fit within the first quadrant in the UV editor.
yes they are. I'm using 4 UDIMs and all the shells are inside those 4 if that's what you mean.
I mean on this quadrant
Try adding a layer at Top and paint on it
the parts that can't be painted, have proper UVs ?
is the texture resolution very small ?
I'm new to 3d coat and can't find where that texture editor is. But the UVs are proper and the resolution isn't small. Also the layer on top didnt work. I opened it in maya and I can add textures over those parts without any stretching or issues
  • Confused 1
The model has 4 uDims and 4 Materials (that has the same shader type assigned)
Separate by materials if you have -like ex- SSS shader
You dont need 4 materials to separate uDims
Also the UVisland is very small, there is not pixel density to paint over
Once I resize the UV island that can not be painted,
the issue was solved
I found that UV islands are distributed on several UV spaces, put all islands related to uDim_1001 on UV square 1001, islands related to uDim_1002 on UV square 1002 and so on
This works best if all objects share the same uv layout.
Take a look at this videos taht show how uDims works on 3DCoat
