Advanced Member bisenberger Posted January 1 Advanced Member Share Posted January 1 (edited) Points to Polygons not working with On Plane version 2024.31. It doesn't work when set to an Axis and Base is zeroed out. Add/Split works as expected with On Plane. Edited January 1 by bisenberger add additional information Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted January 1 Author Advanced Member Share Posted January 1 Sorry for second post, I keep forgetting to turn on Follow topic. Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted January 2 Advanced Member Share Posted January 2 mine works fine ... 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Elemeno Posted January 2 Advanced Member Share Posted January 2 3 hours ago, bisenberger said: Sorry for second post, I keep forgetting to turn on Follow topic. set your normal to -1 its inverted . 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted January 2 Author Advanced Member Share Posted January 2 Thanks for quick response Elemeno. I clicked Y and that set 1 to positive hit the x to zero out the base, still not working for me. Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted January 2 Author Advanced Member Share Posted January 2 If I set Type of Surface to "ZX - Plane" it works fine, but then I can't put in an offset from the plane. Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted January 2 Author Advanced Member Share Posted January 2 I'm following the instructions in this 3D Coat training video on the 3D Coat channel on Youtube. His discussion about using the On Plane feature with Points on Polygons starts at about 10:00 minutes into the video. Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted January 2 Author Advanced Member Share Posted January 2 I miss understood what you said about setting the normal to-1, it works. Thank you! Quote Link to comment Share on other sites More sharing options...
