Paint & UV Room Needs Some Love
swifty
Hi all & Happy New Year
Paint Room
It would be great if the paint room got some additional love in the form of a few more paint tools -
Easily add Transparency/Alpha to a painted/masked region not just object based and not to have to mess around with Layer 0
Colour Curves
Gradient Tool - Needs better control with stop points at either end to better control the gradient region - this could be such a powerful tool especially as you can already add textures/depth images but needs better controls
More Procedural noise types
Paint Effects such as spray paint & directional blur
Mask Generators & Builders- Based on axis, Leaks, Dripping etc - similar to those in Substance Painter
UV Room
UDIM creation
Thanks
  • 2 weeks later...
Hi
Suggestions for development should be submitted to support@3dcoat.com
This is a community forum, and any suggestions here are likely to be missed by people who make those decisions.
21 hours ago, Galnart said:
Would be cool if you could create a curvature then tweak it's width.
Once you've calculated your curvature map, from the Edit menu--> Calculate curvature, you can use these three parameters to tweak it. See video I attached.
It's better to duplicate requests here too. I keep a special document with requests for new features.
Paint Room
Colour Curves
UV Room
UDIM creation
Thanks
I agree 110% with these + ADJUSTMENT LAYERS + better optimized brush performance when using a larger brush radius. It is not practical to always keep the brush radius small to medium size simply to avoid a drastic drop-off in performance (once a brush size is scaled up to a large radius). If Andrew did a fundamental overhaul of the paint brush engine, I think he would discover how to solve this bottleneck. Other companies (Mudbox & Substance Painter for example) have, so I know Andrew can. Computers have gotten so much faster in the past decade or so, yet the same problem persists no matter how robust a user's system is. That is a software based bottleneck, not a hardware one.
  • Like 3
