Blender Applink
swifty
Go to solution Solved by swifty,
The Blender Applink was working great one day, the next it wasn't. Figured out that the problem arose because I opened a Blender file from another user that doesn't have 3DC so they didn't have the Applink add-on installed.
The Exchange Folder and Object/Texture folder was empty under the scene tab-3D Coat Applink settings. This is despite the fact that I do have 'Load UI' unchecked in Blender's preferences so in theory, it should have loaded all my default UI settings including the Applink details. This must be a bug, surely
I have uninstalled the addon - done a restart, reinstalled addon
It now reads as...
Exchange Folder = C:\Users\name\Documents\AppLinks\3D-Coat\Exchange\
Object/Texture folder = C:\Users\name\Documents\3DC2Blender\ApplinkObjects\
It's still not working. It's sending an *.fbx to the location but when you open 3DC it's not there, nothing appears
Can anyone confirm these are the right exchange & object/texture locations ? Or how to get it working again
When opening another users Blender file - can it be fixed so that it retains the relevant 3d Coat Applink Settings
Thanks in advance
https://3dcoat.com/forum/index.php?/topic/31119-blender-applink/
Is right, my Exchange folder is also located on
C:\Users\<username>\Documents\AppLinks\3D-Coat\Exchange\
Object texture folder, I let it empty
reinstall the addon on Extension folder, not Addons
https://3dcoat.com/forum/index.php?/topic/31119-blender-applink/#findComment-197697
  • Solution
Hi,
It's no longer there - all because I opened someone's file that doesn't use 3D Coat - this must surely be a bug? And needs fixing
I downloaded from GitHub - change the download name from io-coat3d_main to io-coat3D and now it seems to be, on a primarily test, working again. I did not delete any files or folders whatsoever.
Thank you for your help, its appreciated - Hopefully, it's all working again
https://3dcoat.com/forum/index.php?/topic/31119-blender-applink/#findComment-197701
  • 4 weeks later...
Where can I get the 3D-Coat Blender addon for Blender ver 4.3.2. The GET ADD-ONS feature in 4.3.2 does not find the addon.
I have Blender 4.2 and the addon works fine there.
https://3dcoat.com/forum/index.php?/topic/31119-blender-applink/#findComment-198007
