Using a stylus as soon as I start drawing, a black line appears dragging the sculpt tool a few inches away from where it should be
BradG
Go to solution Solved by BradG,
Does anyone know why this is happening? I am sculpting the box. If I use the mouse it works fine. If I use a stylus, my stylus pointer is at the corner of the box where it should be, but as soon as I start drawing, a black line appears moving the sculpting cursor a few inches away from where it should be. So now, that circle is digging into the face of the box instead of sculpting the edges. As soon as I lift the stylus, the cursor jumps back to where it should be. Any ideas what is going on??
Thanks
Edited by BradG
  • Solution
Thanks. I don't seem to have steady stroke in my panel. I was using scrape.
Edit* Okay, I see other tools do have it.
I restarted 3d coat, started a new project and now it seems to be fine. If it happens again, I will check out steady stroke.
