  • 0
Details to low poly models
RN3000
Question
Hello,
Since I have experience with ZBrush, I wanted to ask if there's a similar workflow in 3DCoat to "Project All" for transferring high-resolution details onto a low-poly model. In ZBrush, the process involves duplicating the mesh, reducing the polygon count, and then using the "Project All" button to apply the details. Does 3DCoat offer a comparable method?
Thanks!
4 answers to this question
  • 0
Carlosan
Elemeno was awarded the badge 'Helpful' and 1 points.
reproject tool does this , point of this tool isnt the same as zbrush or even blender projection
the reason you project all is to have a better topology after your concept work ,unfortunately 3dcoat convert erverything in tris and voxelises if you add geometry so holding a good topology is almost impossible but yes this works more or less the same
  • 0
Tactical watch, as I'm curious too.
It's not even about hp projection to lp, more like reducing poly count without loosing much of a detail and without doing uneccessary manual retopo work.
Answer this question...
