New Member geese Posted March 31 New Member Share Posted March 31 I am slowing "running" away from Microsoft and its painful because so much software that I use has been written for windows including Zbrush (no linux support). For some very annoying reason when it comes to creatives everything seems to locked either to Windows or Mac (overpriced and overrated), I dont know why, its very irritating. Because its difficult, for now I have set up a laptop to test run Daul boot with Linux and windows (dual ssd and dual boot)! Some years ago I purchased a copy of Zorrin Pro (not my idea) and decided to use that mostly because I paid for it and it was Linux with training wheels. Up until now I have only been using 3D Coat for its far superior retopology tools. Tried to open 3D coat on there after the extraction of the files and it just doesnt want to do anything. I dont know why. I get notification no application installed for "shared library". Then I get "MIME Types required" requesting additional software. Is there a difference between how Pop Os runs and Zorrin? I dont particularly what to have to change it, it take me ages to get Daul boot to work. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 31 Share Posted March 31 Hi Have you used the latest version of 3DC Linux? On 3/25/2025 at 8:54 AM, SERGYI said: I have re-uploaded "3DCoat 2025.01" for Linux:https://pilgway.com/~sergyi/links-Linux.html Only one file has changed: 3DCoat-2025.01/LinuxLibs/libfbxsdk.so To make FBX export/import work in your existing "2025.01", you can download the updated archive and copy only the file "libfbxsdk.so" from the downloaded version into the already used "2025.01". The new "libfbxsdk.so" is bigger than the old one. Quote Link to comment Share on other sites More sharing options...
New Member geese Posted April 23 Author New Member Share Posted April 23 On 3/31/2025 at 1:08 PM, Carlosan said: Hi Have you used the latest version of 3DC Linux? Thanks. I have since tried to run 3D Coat in Zorrin but have found there is a pile of files missing in zorrin that would have enabled 3D Coat to run and adding them would have cause problems. So in the end I flashed Pop os to a spare drive I had. Loaded everything fine from there. Quote Link to comment Share on other sites More sharing options...
