Member JoPPa Posted May 8, 2025 Member Share Posted May 8, 2025 Is there a way to get AmbientOcclusion on multiple UDIMs, tiles? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/31500-ambientocclusion-_-udim/ Share on other sites More sharing options...
Advanced Member Elemeno Posted May 8, 2025 Advanced Member Share Posted May 8, 2025 49 minutes ago, JoPPa said: Is there a way to get AmbientOcclusion on multiple UDIMs, tiles? i believe so , if you import a mesh with multiple udims the ambient occlusion will bake the for whole mesh and apply it to all uvs Quote Link to comment https://3dcoat.com/forum/index.php?/topic/31500-ambientocclusion-_-udim/#findComment-199288 Share on other sites More sharing options...
Member JoPPa Posted May 8, 2025 Author Member Share Posted May 8, 2025 30 minutes ago, Elemeno said: i believe so , if you import a mesh with multiple udims the ambient occlusion will bake the for whole mesh and apply it to all uvs I only get ambient on the first tile, the rest are black. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/31500-ambientocclusion-_-udim/#findComment-199289 Share on other sites More sharing options...
Advanced Member Elemeno Posted May 8, 2025 Advanced Member Share Posted May 8, 2025 28 minutes ago, JoPPa said: I only get ambient on the first tile, the rest are black. i got work in 4 hours otherwise i would quickly set up a scene and test , ill be home in about 16 hours and ill quickly do a test ,unless someone else checks. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/31500-ambientocclusion-_-udim/#findComment-199291 Share on other sites More sharing options...
Member Solution JoPPa Posted May 8, 2025 Author Member Solution Share Posted May 8, 2025 1 hour ago, Elemeno said: i got work in 4 hours otherwise i would quickly set up a scene and test , ill be home in about 16 hours and ill quickly do a test ,unless someone else checks. It's ok, after I restarted 3dcoat... it did the AO correctly. Thanks. 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/31500-ambientocclusion-_-udim/#findComment-199292 Share on other sites More sharing options...
