Member tapanojum Posted May 9, 2025 Member Share Posted May 9, 2025 Hi, I'm having some frustrating issues. On Ubuntu 24.04, I'm unable to add smart materials via "Install Extentions" or simply dragging the 3dcpack into the smart materials folder. I'm hit with "Migration error" unable to rename file from /home/user/Documents/3DCoat/patterns/Fabric/MTL00587_Fabric4k.pbrm to (/home/user/Documents/3DCoat/UserPrefs/SmartMaterials/Fabric/MTL00587_Fabric4k.pbrm. This error happens for all 3dcpacks. This is on the 3DC 2025.01 build as well as 2024_321. Alternatively, I've installed the windows build via wine, which seems to work much better than the native Linux version. I'm able to install smart materials and other 3dcpacks without issue. However, I'm unable to get Blender applink to work with 3DC on Wine, whereas it works with the Linux version. Any advice on resolving either of these issues? I don't care if it works natively or on Wine, I just want it to work.Edit: 3DCoat creates a patterns/Fabric folder in /home/user/Documents/3DCoat/patterns/Fabric/ , it populates it with the textures from a smart material, displays the "Migrate error!" message, asks for 3DCoat to restart and then automatically deletes the patterns/Fabric folder. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/31505-ubuntu-2404-lts-frustrations/ Share on other sites More sharing options...
Member tapanojum Posted March 12 Author Member Share Posted March 12 Wow, it's been nearly a year. Decided to revisit 3Dcoat on Linux. Using Fedora 43 now and still the same error. I ended up manually changing the name of existing folders in /home/user/Documents/3DCoat/UserPrefs/SmartMaterials/ to start with capitals i.e fabric -> Fabric. Now I'm able to install new smart materials via "Install Extensions" without errors. No idea if there will be any consequences for this change. However, I've discovered that mouse wheel scroll doesn't work. Always something In case this helps people using other distros, I've had good results running Ubuntu 24.04 inside Distrobox. Just have to install some missing libraries within the Distrobox container. #install fuse sudo apt install fuse #install missing libraries sudo apt update && sudo apt install -y libgtk2.0-0 libcanberra-gtk-module libpackagekit-glib2-18 libnss3 libcanberra-gtk3-module packagekit-gtk3-module Then have to download fbx-sdk and install it inside the container as well. Everything seems to work, including the app-link with Blender 5.0. Well, everything except the mouse scroll wheel. Tested on the Linux 2024 and 2026 builds. No download links available for 2025. 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/31505-ubuntu-2404-lts-frustrations/#findComment-204041 Share on other sites More sharing options...
