Pressure sensitivity not working on XPpen artist 13 2nd gen and Linux mint 22.1
Kazal.meow
  • New Member
Hello, I've wanted to give this software a try and see if it'd be worth the money, but the pressure sensitivity has not been working on any brushes/tools I've tried in both sculpting and texturing. Does anyone know a way to fix this issue ?
Hi
Go to Preferences >Tablet Library
This option let you select input used by "3DCoat". Switch between two tablet libraries: "WinTab" and "Tablet PC".
Currently "3DCoat" uses "WinTab" which will work only if you will install Wacom "WinTab" driver.
When using "Tablet PC" library which should work without additional Wacom "WinTab" driver.
or
Try switching this icon to pen (pressing LMB over the icon)
Hope this help
//edit
I forgot to add this old video showing sensitivity fine tuning on Preferences
  • New Member
Hello, sorry for the late response,
Thank you for the help, but even after executing that in the terminal, the pressure sensitivity still doesn't work.
Is there something else I may be missing ?
  • 2 weeks later...
  • 11 months later...
