Member Aerovisual Posted July 4 Member Share Posted July 4 Hi, I've started my 3DCoat journey just 5 days ago and I love the sculpting aspect of the software. However the thing that became a huge roadblock for me is the exporting part. I'd like to export my sculpts to Substance Painter and Cinema4D but having difficulty with the normals. Here are my steps: Once the sculpt is complete I retopo via decimation and set the poly count. Then I bake w/ normal map (per pixel): https://imgur.com/S0lggXE https://imgur.com/78JdCB5 I check the object with and without the normal map in the painting room: https://imgur.com/UxfArhA Notice the model looks correct with the normals on: https://imgur.com/PE1TQop Then I export: https://imgur.com/4qe51Bu When I open the model in Substance and add the normal map the model looks as if it doesn't have the normal maps at all: https://imgur.com/IcaL5Ty https://imgur.com/gb8AL06 https://imgur.com/undefined I see the same result when I import the object in Cinema4D. Somehow the normals don't correct the model as they do in 3DCoat's painting room. Here's the 3DCoat file that I use: https://drive.google.com/file/d/1CoJ5iPt_l2JDKE6yHQxSoEVqJZfQDeJ_/view?usp=sharing Thank you. Quote Link to comment Share on other sites More sharing options...
Dmitriy Nos Posted July 4 Share Posted July 4 1 hour ago, Aerovisual said: Here's the 3DCoat file that I use: Hi! Try exporting the scene I attached. If it imports correctly into a third-party application, you need to change the scan depth before baking. normals_test.3b Quote Link to comment Share on other sites More sharing options...
Member Aerovisual Posted July 4 Author Member Share Posted July 4 Hi Oleg, Thanks for the reply. I did try your file. Again it works in 3DCoat but when I import to Substance or C4D I get the same distorted model. My export settings from your file: https://imgur.com/NBkan4T Model in Substance Painter with normal map applied: https://imgur.com/wppJlKD Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 5 Share Posted July 5 - Baking scan settings - I changed snapping method - Export Preset from baking - Result on 3DC normals_test.3b - Export preset for paint room - SP import - painter * remember to import the external baked maps //edit - Add preset - Presets can be found on C:\Program Files\3DCoat-2025\data\ToolsPresets\ExtTools ExtTools.rar 1 Quote Link to comment Share on other sites More sharing options...
Member Aerovisual Posted July 5 Author Member Share Posted July 5 Where can I find your Normal map preset? When I bake with default Substance painter preset the normals come out empty. Quote Link to comment Share on other sites More sharing options...
carrots Posted July 5 Share Posted July 5 1 Quote Link to comment Share on other sites More sharing options...
Member Aerovisual Posted July 5 Author Member Share Posted July 5 Unfortunately even Carlosan's project file looks deformed on my machine: My export settings: Substance: Quote Link to comment Share on other sites More sharing options...
Member Aerovisual Posted July 5 Author Member Share Posted July 5 I have also tried in 3dCoat 2024 and updated the Nvidia drivers. Still cannot get clean results. Quote Link to comment Share on other sites More sharing options...
Member Aerovisual Posted July 5 Author Member Share Posted July 5 (edited) Finally I've solved the issue. It was the Z-Up Coordinate system. I was using z-up because the orientation of the imported object was bothering me (making it hard to orbit the camera) in Substance Painter. With the fallowing bake settings I finally got a decent import in SP: Thanks everyone for your help! Edited July 5 by Aerovisual 2 Quote Link to comment Share on other sites More sharing options...
