Fserver mac setup help
Matti
  • New Member
Hello,
I'm trying to set up a Fserver on a mac server to distribute our floating 3dcoat v4 licenses. The only documentation that I have found is for Catalina, and seems to be missing some information. On top of that it breaks the dns / proxy settings on the mac. Could someone assist with this please?
https://3dcoat.com/forum/index.php?/topic/32074-fserver-mac-setup-help/
Hello
Your request was forwarded at
support.linux@pilgway.com
- If you defined the "COAT_FSERVER" environment variable then usual licensing will not work, only local network/fserver will be the source of the license.
So, if by some reason license does not work, please check if this variable is not declared or if declared - it should be declared correctly, as the server_ip:port.
