philnolan3d Posted August 2, 2009 Share Posted August 2, 2009 You may not know it but if you have an nVidia 8800 GTS you also have a Quadro. I just briefly heard about this soft-mod but it supposed to give a big improvement for 3D apps. Here's a couple of tutorials. Do it at your own risk of course, but I understand its fairly safe. http://www.techarp.com/showarticle.aspx?artno=539&pgno=0 http://www.rage3d.com/board/showthread.php?t=33898714 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/3274-softmodding-an-nvidia-8800-gts/ Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted August 2, 2009 Reputable Contributor Share Posted August 2, 2009 You may not know it but if you have an nVidia 8800 GTS you also have a Quadro. I just briefly heard about this soft-mod but it supposed to give a big improvement for 3D apps. Here's a couple of tutorials. Do it at your own risk of course, but I understand its fairly safe.http://www.techarp.com/showarticle.aspx?artno=539&pgno=0 http://www.rage3d.com/board/showthread.php?t=33898714 Doesn't work with new cards, aye? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/3274-softmodding-an-nvidia-8800-gts/#findComment-25508 Share on other sites More sharing options...
philnolan3d Posted August 2, 2009 Author Share Posted August 2, 2009 I don't know, I only have an 8800 GTS so I didn't look at others. That first link does say that GeForce hardware is identical to Quadro. He didn't specify which GeForce. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/3274-softmodding-an-nvidia-8800-gts/#findComment-25511 Share on other sites More sharing options...
Advanced Member geo_n Posted August 2, 2009 Advanced Member Share Posted August 2, 2009 a friend did that with his 6600gt agp card I think but it didn't make a difference since he was using lw 8.5 that time. LOL! Quote Link to comment https://3dcoat.com/forum/index.php?/topic/3274-softmodding-an-nvidia-8800-gts/#findComment-25514 Share on other sites More sharing options...
Advanced Member cuffins Posted August 3, 2009 Advanced Member Share Posted August 3, 2009 I don't know, I only have an 8800 GTS so I didn't look at others. That first link does say that GeForce hardware is identical to Quadro. He didn't specify which GeForce. It depends on your graphic cards GPU. Here is an other short description: Soft Modding 8800GTS It's also possible with older cards. But in newer ones NVIDIA prevented soft modding by laser cutting their chips I've heard... I have soft modded my 8800GTS to Quadro FX 4600. It speeds up OpenGL performance in some (not all) applications. In Cinebench I will get 6500 points in OpenGL bench instead of 5500 with original driver. But unfortunately I didn't notice any speed enhancements in 3DC... Quote Link to comment https://3dcoat.com/forum/index.php?/topic/3274-softmodding-an-nvidia-8800-gts/#findComment-25691 Share on other sites More sharing options...
philnolan3d Posted August 3, 2009 Author Share Posted August 3, 2009 Unfortunately I tried following some of the directions I found (they are also in your link, Cuffins) but it didn't work out for me, the file in the Quadro driver was different from how they described it. I guess it's no big deal, I wasn't sure if I wanted to do it or not anyway. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/3274-softmodding-an-nvidia-8800-gts/#findComment-25693 Share on other sites More sharing options...
Guest Cinnamon Posted August 29, 2009 Share Posted August 29, 2009 Nice technique, I'm going to try this out. I hope it works. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/3274-softmodding-an-nvidia-8800-gts/#findComment-28071 Share on other sites More sharing options...
