  • 0
Applink install - No 3D coat window popup
sheeplion
Question
I have 3Dcoat 2025.17. I clicked the 3Dcoat window about Blender Applink away. Thinking I could find it trough Blender. But cannot. Now I try to get the popup again, but it no longer shows up. How can I install the Applink addon now?
Would be nice if I could download it and install manually.
blender version 4.5.7 LTS
Thank you in advance.
3 answers to this question
  • 0
Hi
Default addons are not working anymore
Please take a look -> how to resolve it
On latest versions Blender AppLink was updated to be able to exchange data with 3DCoat just from scratch install.
So, just install 3DCoat, Blender, follow what 3DCoat tells (easy to follow) and then you may easily drop assets to Blender, including Factures
Did you follow this steps ?
  • 0
Posted (edited)
I downloaded the Applink 4.1 version and installed it into Blender 4.5.7 LTS. I could send a simple cube:
Your link you gave, from the other forum post (Applink Blender 4.1): https://projects.blender.org/extensions/io_coat3D
Other link for APPlink version (Blender 4.2 / 4.3): https://github.com/AndrewShpagin/io-coat3d
Edit:
link from Blenders side with several version of Applink:
https://extensions.blender.org/add-ons/coat-applink/versions/
Blender 4.5 is shipped with version 5.0. It does not always show up right away. I do not understand why. after I installed an older version it also avctivated 5.0 also. 2 versions active. So, I disabled an older one then.
Hope fully the get back function will work too. Otherwise it is no biggy. Than just manual import / export then. Thank you so far.
Edited by sheeplion
Answer this question...
