Member Andreas Wolmer Posted Tuesday at 05:06 PM Member Share Posted Tuesday at 05:06 PM (accidentally posted this in Tutorials section first, moving it here as it's actually a functionality question) Hi! I'm trying out some sculpting with layers (in Surface Mode), and just wanted to check if the layer masks are supposed to work with sculpt information? Because I can't seem to make it work. Cheers Andreas Quote Link to comment https://3dcoat.com/forum/index.php?/topic/33702-layer-mask-not-working-with-sculpt-information/ Share on other sites More sharing options...
Dmitriy Nos Posted Tuesday at 06:11 PM Share Posted Tuesday at 06:11 PM @Andreas WolmerHi! Masking, as implemented in Paint Room, isn't implemented in the Sculpt room on sculpt layers. However, you can use sculpt layers to modify surface geometry and hide them when needed. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/33702-layer-mask-not-working-with-sculpt-information/#findComment-203918 Share on other sites More sharing options...
Member Andreas Wolmer Posted Tuesday at 06:15 PM Author Member Share Posted Tuesday at 06:15 PM 2 minutes ago, Dmitriy Nos said: @Andreas WolmerHi! Masking, as implemented in Paint Room, isn't implemented in the Sculpt room on sculpt layers. However, you can use sculpt layers to modify surface geometry and hide them when needed. Ok, thanks for the reply. Perhaps a future feature, one could hope. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/33702-layer-mask-not-working-with-sculpt-information/#findComment-203919 Share on other sites More sharing options...
