Carlosan Posted May 13 Share Posted May 13 Source... Read Usage.txt to read further installation details This addon installation is currently set to work witch RizomUV 2025. (Also can be set to unfold3D if you need to work with older versions) Install: Drag the .3dcpack into 3DCoat or AddOns → Install Extension or "File > Install > Install Extension" then restart 3DC After the install, you can find it in the Addon Menu. 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/34158-rizomuv-3dcoat-bridge-works-with-3dcoat-2025/ Share on other sites More sharing options...
