Extrude option gone...?
DustyShinigami
Go to solution Solved by Gorbatovsky,
Have things drastically changed in 3DCoat since I last used it...? Has the Extrude option been moved? I've selected a ring of edges that I want to extrude, but the only option I see now is Smart Extrude. I thought there was a standard method of extruding? It has been a while since I last retopped something in 3DCoat. Again, I did see mention in an old thread that it's in the Command menu, but it doesn't show for me. I only have Add Geometry, Tweak, UV, Selected, and Entire Mesh.
https://3dcoat.com/forum/index.php?/topic/34605-extrude-option-gone/
On 7/6/2026 at 8:40 PM, Carlosan said:
> Extrude (On Select Transform or Smart Extrude) only works with Faces.
Was changed to prevent bugs.
//bad info, was corrected below
I'm not sure I follow. I don't see an Extrude option when using Select Transform for faces or edges. Smart Extrude appears to be the only one that lets me extrude a face or an edge.
The development of version 2026 (current is v2026.05) is on Beta stage, not ready for production.
for daily use continue with latest 2025 version
* remember to select on Edit the location of 3DC folder on //documents for every version to avoid any bug.
  • Solution
The Smart Extruder tool works with faces and edges.
  • Thanks 2
Yeah, this definitely works. I was just wondering what happened to the original Extrude option that I've used in the past, but if it was replaced/changed to fix bugs, then that's that. :)
