Advanced Member DustyShinigami Posted July 25 Advanced Member Share Posted July 25 Hi. How exactly can you select a specific coloured cluster of faces? What I mean is, I've added UV seams, so areas are separated into different colours - green for the front faces of the mesh, purple for edges on top, bottom, and the sides, and yellow for the inside faces - and I want to select just the front and edge regions so I can delete them. But using the Select tool, double clicking on any coloured region just selects everything. I've tried Unwrapping it all to see if I can select the Shells in the UV Preview window, but I'm not having any luck with that either. Thanks Quote Link to comment https://3dcoat.com/forum/index.php?/topic/35230-retopo-how-do-you-select-cluster-of-different-coloured-regions/ Share on other sites More sharing options...
Solution Dmitriy Nos Posted July 25 Solution Share Posted July 25 @DustyShinigamiYou can do this in the UV preview window. Click on the UV island and delete it. 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/35230-retopo-how-do-you-select-cluster-of-different-coloured-regions/#findComment-206689 Share on other sites More sharing options...
Advanced Member DustyShinigami Posted July 25 Author Advanced Member Share Posted July 25 1 hour ago, Dmitriy Nos said: @DustyShinigamiYou can do this in the UV preview window. Click on the UV island and delete it. Awesome. Thank you. Although, I could have sworn when I tried selecting things in the UV Preview window, it wouldn't select anything. Or just everything instead of individual shells. But that's sorted it. 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/35230-retopo-how-do-you-select-cluster-of-different-coloured-regions/#findComment-206690 Share on other sites More sharing options...
