Andrew Shpagin Posted September 7, 2009 Author Share Posted September 7, 2009 Update postponed to tomorrow. Need refine and test all more carefully. Especially new curves improvements - possibility to re-pose curves skeleton. Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28866 Share on other sites More sharing options...
Advanced Member wailingmonkey Posted September 7, 2009 Advanced Member Share Posted September 7, 2009 Andrew, on your blog you've stated: "There is some heuristics in determining what is parent and what is child. I suppose the more massive part to be a parent." Wouldn't the parent-child decision be made based upon order of creation, or am I misunderstanding? *edit* oops...forgot that we can insert new curve nodes in-between previously created nodes...my bad. (but maybe that is the first check -order of creation-, and the second is based upon larger mass of curve branches above node in question...) Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28876 Share on other sites More sharing options...
Advanced Member akira Posted September 7, 2009 Advanced Member Share Posted September 7, 2009 Andrew, on your blog you've stated:"There is some heuristics in determining what is parent and what is child. I suppose the more massive part to be a parent." Wouldn't the parent-child decision be made based upon order of creation, or am I misunderstanding? *edit* oops...forgot that we can insert new curve nodes in-between previously created nodes...my bad. (but maybe that is the first check -order of creation-, and the second is based upon larger mass of curve branches above node in question...) I think the most flexible way is to let us choose(or toggle) which part to be the parent ourselves, a hotkey or a button should work well. akira. Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28878 Share on other sites More sharing options...
Advanced Member kay_Eva Posted September 7, 2009 Advanced Member Share Posted September 7, 2009 I think the most flexible way is to let us choose(or toggle) which part to be the parent ourselves, a hotkey or a button should work well.akira. Yeah blender let's you choose parents by shift-select, then ctrl+P Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28881 Share on other sites More sharing options...
Advanced Member jacobo Posted September 7, 2009 Advanced Member Share Posted September 7, 2009 I was working on a character sculpt thru the weekend and came across something with Voxel Layers that really made me sweat. I had to have each tooth in it's separate layer so as not to have it blend in with its neighbors. But then I changed my mind and decided to merge them all. Since currently there is no single way to do this, I had to right click on every tooth layer and give the command to merge them to one. And after that was done, I had to go in and delete the old ones (a total of 48 steps) And with the context menu being so jumpy, it wasn't that easy to do either... So my suggestion would be to get the Voxel Layers to work more like in Photoshop, which could be something like this: 1- Multiple selection of layers for batch editing (like parenting and merging) could be implemented. --> select multiple layers and say "Merge Selected" and/or "Merge to" and/or "Parent to" or maybe even "Subtract from" could subtract the additive volume of all of these layers from a certain volume layer. 2- Drag and Drop support for Layer hierarchy and/or stratification adjustments --> It could be great if one layer could be dragged and dropped onto another for parenting or to change their places in the stack 3- Additional commands --> Like "Subtract from and keep original" (The default deletes it), "Merge to and keep Original" (The default is reset to delete it) What do you guys think? Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28894 Share on other sites More sharing options...
Member VolumesculptR Posted September 7, 2009 Member Share Posted September 7, 2009 Yeah, multiple selection is a nice one for feature request ! And for # 2. You CAN do such things: just drag (child) layer to it's parents' PLUS sign (no the layer's name) [+ will highlights BTW] Though this option (dragging onto PLUS-sign) doesn't work if you decide to have Root as parent (you'll have to drag child layer onto some other layer) to make ex-child separate one... May be I didn't quite understand but changing layers order is quite simple I guess (just drag inbetween upper/lower layer) something like: Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28898 Share on other sites More sharing options...
philnolan3d Posted September 7, 2009 Share Posted September 7, 2009 I agree, those are good ideas. You should make a feature request for them. Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28899 Share on other sites More sharing options...
Advanced Member jacobo Posted September 7, 2009 Advanced Member Share Posted September 7, 2009 Yeah, multiple selection is a nice one for feature request!And for # 2. You CAN do such things: just drag (child) layer to it's parents' PLUS sign (no the layer's name). Yeah, any method Andrew would find fit to work in the API really, would do just fine... I bet a lot of people have run into this and it really looks quite needed in 3DC... I agree, those are good ideas. You should make a feature request for them. Andrew checks out this thread quite often, but nevertheless at the risk of imposing (as always hehee) I'll PM him to make sure he doesn't miss this request... Cheers; AJ Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28900 Share on other sites More sharing options...
Contributor LJB Posted September 7, 2009 Contributor Share Posted September 7, 2009 Yeah Multiple selection and Hirachial merging have been on my request lists for a while I Posted it several times in the Last month in the buildup to the 3.1 release. Stick it in the feature requests again and you get a +1 here. Needed badly when you have complex scenes with lots of Hirachial holders for multiple children. Its a pain in the butt to merge them all manually. Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28902 Share on other sites More sharing options...
Contributor LJB Posted September 7, 2009 Contributor Share Posted September 7, 2009 Hi;May I squeeze in a little request? As of now, when you draw a rectangular marquee over a volume (or freehand lasso or etc), pressing CTRL chops off the area inside the marquee region. To do just the opposite, you have to go through a few steps more. I think it would be great to give the marquee, lasso, freehand, circle and etc tools the ability to do the both. Like by holding down CTRL and drawing a marquee region you could keep the outside and do away with the inside like the current state. And by holding down say CTRL+SHIFT and drawing a region, you could keep the inside and do away with the outside. Would really improve the voxel workflow IMHO... Cheers; AJ That is a NICE Idea Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28903 Share on other sites More sharing options...
Advanced Member jacobo Posted September 7, 2009 Advanced Member Share Posted September 7, 2009 Yeah Multiple selection and Hirachial merging have been on my request lists for a while I Posted it several times in the Last month in the buildup to the 3.1 release. Stick it in the feature requests again and you get a +1 here. Needed badly when you have complex scenes with lots of Hirachial holders for multiple children. Its a pain in the butt to merge them all manually. Ok, also added to the feature request thread... cheers AJ Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28904 Share on other sites More sharing options...
Advanced Member jacobo Posted September 8, 2009 Advanced Member Share Posted September 8, 2009 There's a bug with stamp brush and the merge object tool. The object chosen to be merged using a pen is stamped skewed away from the surface normal of the volume it is stamped on (See attachment) Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28953 Share on other sites More sharing options...
Andrew Shpagin Posted September 8, 2009 Author Share Posted September 8, 2009 I was working on a character sculpt thru the weekend and came across something with Voxel Layers that really made me sweat. I had to have each tooth in it's separate layer so as not to have it blend in with its neighbors. But then I changed my mind and decided to merge them all. Since currently there is no single way to do this, I had to right click on every tooth layer and give the command to merge them to one. And after that was done, I had to go in and delete the old ones (a total of 48 steps) And with the context menu being so jumpy, it wasn't that easy to do either... So my suggestion would be to get the Voxel Layers to work more like in Photoshop, which could be something like this:1- Multiple selection of layers for batch editing (like parenting and merging) could be implemented. --> select multiple layers and say "Merge Selected" and/or "Merge to" and/or "Parent to" or maybe even "Subtract from" could subtract the additive volume of all of these layers from a certain volume layer. 2- Drag and Drop support for Layer hierarchy and/or stratification adjustments --> It could be great if one layer could be dragged and dropped onto another for parenting or to change their places in the stack 3- Additional commands --> Like "Subtract from and keep original" (The default deletes it), "Merge to and keep Original" (The default is reset to delete it) What do you guys think? 1 - will be done some day, but really not so easy because introducing multiple selection will make more complex handling of many existing operations. 2 - Try SHIFT+drag layer 3 - ok, that is not hard - the only prob is growing of RMB menu Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28957 Share on other sites More sharing options...
Andrew Shpagin Posted September 8, 2009 Author Share Posted September 8, 2009 Hi;May I squeeze in a little request? As of now, when you draw a rectangular marquee over a volume (or freehand lasso or etc), pressing CTRL chops off the area inside the marquee region. To do just the opposite, you have to go through a few steps more. I think it would be great to give the marquee, lasso, freehand, circle and etc tools the ability to do the both. Like by holding down CTRL and drawing a marquee region you could keep the outside and do away with the inside like the current state. And by holding down say CTRL+SHIFT and drawing a region, you could keep the inside and do away with the outside. Would really improve the voxel workflow IMHO... Cheers; AJ I have done it. Wait for next build. Btw good feature to sculpt using some sketch to cut off all behind basic shape. Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28958 Share on other sites More sharing options...
Member Costanel Posted September 8, 2009 Member Share Posted September 8, 2009 Any news on a drawing tool based on single images? Now all tools are focussed on tiling, it is quite hard to draw single shapes and size is easily(for e.g. windows, tatoo's, etc). Thanks in advance, keep up the good work. Link to comment https://3dcoat.com/forum/index.php?/topic/3594-3d-coat-31-updates-thread/page/12/#findComment-28981 Share on other sites More sharing options...
