[Solved] Importing Smoothing Groups from OBJ or FBX
rs3d
When importing FBX or OBJ for Voxel Mode the Smoothing Groups
get ignored. Is there a option to evaluate them and not
creating an edgy, non-smoothed voxel object?
Importing my FBX/OBJ files into other 3D software or viewers
shows that they are smooth, just 3DC ignores this data.
Thanks a lot, Rob
Thanks a lot, Rob
In the other viewers, they aren't smooth, they are rendered as IF they are smooth. If you look at the silhouette it's probably still faceted.
Since the smoothing groups on OBJs / FBX doesn't actually affect the geometry, only the appearance of the shading on that geometry it won't affect the voxels.
The Voxels are simply inside, or not inside the geometry.
If you're hoping for a smoother representation of your mesh, you could use "subdivide" in the merge palette.
But, smoothing groups - won't have affect in voxel-town.
Someone correct me if I'm wrong (pretty sure I'm not though)
I know that the faces are not smooth themselves, but when
importing them the Voxel Importer could take Normal Smoothing
into account like in the other Import modes (PerPixel, Microvert),
where it is called "Auto Smoothing Groups".
Sure making multi-million poly meshes helps, but with lots
of details its quite impossible.
A global Voxel "Smooth All" helps, but fine details are in
danger too.
Best, Rob
  • 5 years later...
Importing to the paint room.
3DCoat by default sets the smoothing groups to your object to 90 degrees when importing objects to the paint room or baking from the retopo room.
In the import panel, choose auto-smoothing groups and set it to the degrees so desired. Start at 30 and then change it if necessary.
The other is texture filter smoothing.
Under the View menu turn off Turn off Linear Texture Filtering. No filtering at all, pixels will clearly be seen.
Note: 3DCoat does support smoothing groups from other software with out using the auto-smoothing groups feature.
I can import a wings3d exported obj file with smoothing groups into the paint room and 3DC imports it correctly...
  • 2 years later...
i was not talking about voxel room simply use import to paint on it.
this method of recalculating may help but is not perfect because majority of time i do them manually because some faces are angled other not and auto smooth don't know what i'm doing.
but well, thanks for your answer, i'll use fbx when the problem is appearing
  • 1 year later...
  • 1 year later...
