Taros Posted October 20, 2009 Report Share Posted October 20, 2009 Hi. I am currently working on a important project. I've painted a normal map on a model and imported the same normalmap into a new scene, where I want to fit the normal map to a similar model. How it is possible to paint on a imported normal map layer??? Or do I have to paint all new? Please! Urgent! Be creative Chris Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted October 20, 2009 Applink Developer Report Share Posted October 20, 2009 Sorry Taros, I tried but no luck. It seems that you can't paint on imported normal maps. And if you try to create new map and then merge with normal layer it goes crazy by doing that. I will keep trying if I find something... Quote Link to comment Share on other sites More sharing options...
Taros Posted October 20, 2009 Author Report Share Posted October 20, 2009 @haikalle: Thank you. But I#ve already painted the map new, because of "no time". I guess, there is currently no possibility to paint on imported normal maps. THAT feature would be really good and save work, espacially if you are working with some similar characters and all of them are based on one main model. Be creative Chris Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted October 20, 2009 Applink Developer Report Share Posted October 20, 2009 I agree. This feature should be added. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 21, 2009 Report Share Posted October 21, 2009 If you have painted some depth in per pixel mode and you want to transfer it to other model you need to export displacement, not normalmap. 3DC operates with displacement on interal level, but displacement CAN'T be recovered from normalmap. 1 Quote Link to comment Share on other sites More sharing options...
Taros Posted October 21, 2009 Author Report Share Posted October 21, 2009 If you have painted some depth in per pixel mode and you want to transfer it to other model you need to export displacement, not normalmap. 3DC operates with displacement on interal level, but displacement CAN'T be recovered from normalmap. Oh Thank you Andrew. That solve my problem! Very nice. Onother question to this topic: How I can be shure that the imported map will have the same depth information like the original? After the depth import, the depth is very strong. I have to set the depth channel on a much lower value to get a similar result like the original. How is it possible to get the exact same results with depth export? Examples: Quote Link to comment Share on other sites More sharing options...
Advanced Member cakeller Posted October 21, 2009 Advanced Member Report Share Posted October 21, 2009 Oh Thank you Andrew. That solve my problem! Very nice. Onother question to this topic: How I can be shure that the imported map will have the same depth information like the original? After the depth import, the depth is very strong. I have to set the depth channel on a much lower value to get a similar result like the original. How is it possible to get the exact same results with depth export? Examples: I think (please someone correct me if I'm wrong) but the depth export provides the current factor right after export. Did you use this factor, and it is coming out wrong? Quote Link to comment Share on other sites More sharing options...
Advanced Member lc8b105 Posted October 21, 2009 Advanced Member Report Share Posted October 21, 2009 After you export the displacement map, there will be a window pop up say :"Depth factor for saved texture: ...." Remember that factor number. When you want to import the exported map next time, enter that factor number. Quote Link to comment Share on other sites More sharing options...
Taros Posted October 21, 2009 Author Report Share Posted October 21, 2009 The factor does nothing... it looks like the image. Could be a bug. I will test it again. Quote Link to comment Share on other sites More sharing options...
Taros Posted October 21, 2009 Author Report Share Posted October 21, 2009 Ok. Have test it. The factor works only in 8bit mode. In 32 Bit the factor have no effect. Bug? using V.3.1.13 CUDA DX 32Bit Quote Link to comment Share on other sites More sharing options...
Advanced Member cakeller Posted October 21, 2009 Advanced Member Report Share Posted October 21, 2009 Ok. Have test it. The factor works only in 8bit mode. In 32 Bit the factor have no effect. Bug? using V.3.1.13 CUDA DX 32Bit That actually makes sense, since 32 bit SHOULD (yes, SHOULD) NOT NEED A factor since it can hold exact 3D displacement info. so, question is, does using 8-bit mode with the factor work PROPERLY? Can it be used for now? and maybe confirm with Andrew if the 32-bit problem is a bug, or a workflow thing we're missing? (Sounds like a bug to me) [EDIT] RIGHT, I forgot about that (wasn't looking at it when I posted) ... Vector Displacement, Black NOT NORMALIZED is ABSOLUTE displacement distances (based on the space of course) I tested, it worked perfectly. So the question to Taros - does it work for you, and for that model? [/EDIT] 1 Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 21, 2009 Report Share Posted October 21, 2009 In 32-bit, black - based, not normalized mode scale should be preserved. Try it. Also there is Depth modulator in Blending layers page. 1 Quote Link to comment Share on other sites More sharing options...
Taros Posted October 22, 2009 Author Report Share Posted October 22, 2009 Thank you for the answers. In my situation the first displacement export option worked the best: "Zero level is gray", the import looks same like the original depth information. "black - based, normalized" was ok too, but smoothy after import. "black - based, not normalized" is good too, if you don't need the exactly same depth map, because it is very strong after import and needs adjustements at depth% (see screenshot in my upper post). Be creative Chris Quote Link to comment Share on other sites More sharing options...
