Contributor artman Posted October 20, 2009 Contributor Report Share Posted October 20, 2009 I think it is critical problem (but not urgent because Im just an amateur ) 3.1.13 32bit cuda Dx and GL Baked results are full of artifacts. With both merging for Microverts and DP. Here are comparative shots between 3.1.13 and 3.1.12. Maybe the problem is more in the automapping than in the baking itself because as you can see in screenshot 3 and 4 and 5, 3DCoat generates a very abnormal number of chunks in the uvs compared to previous version.Autommapping is also much different when using it with merging options from the voxtree than when using auto-seams in the retopo menu. Merging using Dp in 3.1.12 Merging using Dp in 3.1.13(same problems with microverts) Auto-mapping result in 3.1.13 when using any of the merging approaches When using quadrangulate and auto-seams in retopo room instead of using the "quadrangulate for perpixel painting" dialog (much different Uvs far less chunks ) (when using auto-seams and merging from retopo room result is much better but there are still abnormal number of artifacts(6-7)...much more than 3.1.12(1or2artifact only)) note:IT IS NOT RELATED TO FILE, it is the same for all files. Cheers Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 21, 2009 Report Share Posted October 21, 2009 Oh, really. My mistake. Found, reproduced and fixed. It was due to some experiments with auto-mapping. Quote Link to comment Share on other sites More sharing options...
