Twitter discussion: What Andrew is currently doing.
It guarantees normalmaps compatibility.
0 replies0 retweets1 favorite
 Reply
 Retweet
 Favorite1
More
"Draw on plane" extended on Curves/Text/Snake clay
0 replies1 retweet2 favorites
 Reply
 Retweet1
 Favorite2
More
3D-Coat now may import object space normal maps (with auto conversion to tangent space)
0 replies6 retweets6 favorites
 Reply
 Retweet6
 Favorite6
More
Hash Animation master <--> 3D-Coat applink beta test - https://www.hash.com/forums/index.php?showtopic=46804
0 replies2 retweets0 favorites
 Reply
 Retweet2
 Favorite
More
Extra functionnlaity in objectify - removing small flying noise, unifying small pieces, decomposing to child volumes, sorting by size.
0 replies1 retweet0 favorites
 Reply
 Retweet1
 Favorite
More
Seems objectify was super slow. I fixed it in beta6.
Objectify is not a common English word in the context of 3D... Yeah, I went What? too... :blink:
"Separate Pieces" is very easy to understand.
There is no need for the word  "Disconnected" as pieces in common English usage implies that already...
We would say something like, I can get rid of all those pieces as they are not needed...
Edited by digman
Well I agree .Separete Parts is easy to understand... if this tool is about separete parts for a imported object imported with many parts, ( this is the only way I get import objects modeled wit many parts... just with " import to separete instances " activaded in import menu and "imported without voxelization" too.other way I can´t import , always get boolean errors or crash ) the result is a layers with many childrens, and when I click the menu objectify with the mother layer activated , nothing happens...
  • 2 weeks later...
  • 3 weeks later...
  • 2 weeks later...
Finished updating render room, now it renders lights derived from panorama correctly.
It is already possible to render out lighting almost identical to what is displayed in the viewport. Sort of. Although it requires a little bit of tweaking and it doesn't allow for using additional lights.
The workaround I'm using:
  1. Set primary light intensity to 100.
  2. Set ambient light to 0.
  3. Lightness to 500*.
  4. AO percentage to 25*.
  5. Delete all custom lights.
  6. Black out the remaining light by setting its colour to (0,0,0) and intensity to 0.
* - The relation of AO percentage and lightness seems to be an exponential function. I only looked up some samples that work good.
Few pairs that return almost identical results on the rendered images:
lightness    ao_percentage
  1355            10
   500            25
   262            50
   174            75
   130           100
I mostly use pair 262/50.
The pairs return subtly brighter lighting than the viewport as I like it this way, but you can always darken it to almost perfectly match the viewport by slightly lowering the lightness parameter of each pair.
But this all is tedious, so I'm glad it won't be needed any more. :)
Edited by ajz3d
