Load small obj file and it goes inot infinite loop
BUILD: v3.10.17, 64bit CUDA
OS: Windows Vista 64bit, SP2
HARDWARE & DRIVER: 2 x Nvidia GT9800 GT
BUG DESCRIPTION: When I loaded simple and small 3d model in obj format under paint mode and it go into infinite loop. I cannot use mouse, key but hard disk drive busy writing and reading by noting HDD LED flicking continuously for two hours. I decided to hard reboot computer. I tried it again under vowel mode and it works ! I tried it again under paint mode, it crashes again and now I am too scared to use it again. I purchased license in few days ago.
STEPS TO REPRODUCE: I tried to upload model to see if you can emulate this problem but I could not. I will try do that on other computer using windows XP.
Dillip
Dillip
If you would still like to proceed, I think you have hit upon a work around. Load it into Voxels and save as a 3b file, quadrangulate for per pixel Paint and it will open in the Paint room. Then when you are finished painting, export as obj.
Thanks for your alternative solution. I tried this but when I save it into 3B file format and exited the program. I ran 3d-coat again and loaded 3b file and nothing display on the screen ! I am not sure why.. My first thought was 3d-coat program works fine if I created object file using it but it may not work well with object files created by different applications such as Carrara 3d, Hexagon and Silo.
Dillip
Dillip
Send the 3b file/obj to Andrew at support@3d-coat.com
