philnolan3d Posted February 20, 2010 Share Posted February 20, 2010 I've talked about Crazy Bump here before but believe it or not I've found something better. Pixplant does the same thing as Crazy Bump, creates normal, spec, & depth textures from a Photo. I've seen other programs that do this but none matched CB's quality. Pixplant matches the quality if not better, plus it has a nicer interface, plus as a pleasant surprise it also makes the texture seamless. There're also a few more features like straightening or correcting perspective on and image. The best part it's a lot cheaper than CB. This is fantastic for making Materials to paint with in 3DC. http://www.pixplant.com/ Quote Link to comment Share on other sites More sharing options...
Contributor 3d_sculptress Posted February 20, 2010 Contributor Share Posted February 20, 2010 I've talked about Crazy Bump here before but believe it or not I've found something better. Pixplant does the same thing as Crazy Bump, creates normal, spec, & depth textures from a Photo. I've seen other programs that do this but none matched CB's quality. Pixplant matches the quality if not better, plus it has a nicer interface, plus as a pleasant surprise it also makes the texture seamless. There're also a few more features like straightening or correcting perspective on and image. The best part it's a lot cheaper than CB. This is fantastic for making Materials to paint with in 3DC. http://www.pixplant.com/ perfect timing on this post, Phil..I had just ran across a link for CB yesterday n was planning on going back n checking it out more thoroughly today,..,,I have TextureMaker already, and it has oodles of great texture options, but always open for exploring more possibilities, so thanks for posting. Quote Link to comment Share on other sites More sharing options...
Javis Posted February 20, 2010 Share Posted February 20, 2010 Wow, that looks amazingly powerful, and quick. For this type of work I think it would be invaluable. The price is a little steep, but the time saved I suppose one could justify it. The question is: Stand alone or the PS plugin version? Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted February 20, 2010 Author Share Posted February 20, 2010 I'm using the Stand-Alone version, I have a feeling it would have more options than the PS one. It's a little pricey but consider than CB does less and costs $300. Edit: Here I made these textures based on the attached image. http://dl.dropbox.com/u/3083393/grate_01_material.zip You can thank Dave Davidson (@max3ddotorg on Twitter) for telling me about it. Quote Link to comment Share on other sites More sharing options...
Javis Posted February 21, 2010 Share Posted February 21, 2010 That's pretty cool. I'm going to have to pick up a copy of this soon. Thanks for the heads up! Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted April 14, 2010 Author Share Posted April 14, 2010 I was actually just using it again last night and I was blown away again. This is what I got from loading a photo of some wood planks. Quote Link to comment Share on other sites More sharing options...
Advanced Member 3DArtist Posted April 14, 2010 Advanced Member Share Posted April 14, 2010 Nice, that turned out pretty good. Can you bring in existing diffuse, displacement, normal, spec maps and create a tiled version? PhotoSculpt and PixPlant could be a killer combo. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted April 14, 2010 Author Share Posted April 14, 2010 I'm looking through the help file and I don't see any way of doing that, maybe I'm just not seeing it. Quote Link to comment Share on other sites More sharing options...
Advanced Member wailingmonkey Posted April 14, 2010 Advanced Member Share Posted April 14, 2010 3DArtist, from the 'support' section: http://www.pixplant.com/video/screencast4-600/ (shows how to set up the repeating 'seed'...reckon you could allow for much greater variety than that example, tho, with a bigger selection set) Quote Link to comment Share on other sites More sharing options...
Advanced Member 3DArtist Posted April 14, 2010 Advanced Member Share Posted April 14, 2010 Thanks guys. I downloaded the demo and I don't see the option of doing anything non-tiled or using existing maps. It works pretty good for what it does though. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted April 14, 2010 Author Share Posted April 14, 2010 Well if you want no tiling just change this to "None". Quote Link to comment Share on other sites More sharing options...
Advanced Member 3DArtist Posted April 14, 2010 Advanced Member Share Posted April 14, 2010 Sorry, I meant non-seed-generated. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted April 14, 2010 Author Share Posted April 14, 2010 I actually did it on the wood that I used in 3DC, however I couldn't get it to work again when I made the example above. I think all I did was hold Shift when clicking the generate button (which changes to "Generate with current seed only"). Quote Link to comment Share on other sites More sharing options...
