Contributor artman Posted March 23, 2010 Contributor Report Share Posted March 23, 2010 Export Object from voxtree change .obj position. Im currently using 3.2.02 but i think its valid for all builds. It is same issue this guy doing retopo work is having Voxel object has not same position as retopo work. http://www.3d-coat.com/forum/index.php?showtopic=5327. Strangely Export Scene is OK,just Export Object that is broken. Issue is super easy to reproduce with Man Friday's goblin here. http://www.mediafire.com/file/zjymy4k1muy/Goblin_Test.3b You jsut need any other program to see position difference...Zbrush,Mudbox,Topogun ect. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted April 9, 2010 Author Contributor Report Share Posted April 9, 2010 I thought this issue was fixed but again I tried today to bake occlusion in Xnormals and voxel layer has a completely different scale than exported retopo layer. Again as stated above the problem is only when using Export Object from voxtree, 'Export Scene' option respect scale correctly.The problem is from 3dCoat not from Xnormals because scale of imported objects(retopo+voxel layer) does not match in every apps I tried (topogun,zbrush,mudbox..) Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 10, 2010 Report Share Posted April 10, 2010 Ok, I fixed it. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted April 10, 2010 Author Contributor Report Share Posted April 10, 2010 Great news! Thanks Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted April 13, 2010 Author Contributor Report Share Posted April 13, 2010 3.2.10 Cuda DX 64 Seems problem is still there... Now not only scale is wrong,but orientation is also wrong. Problem is not from zbrush because its the same in Mudbox or Xnormals.. here is file for you to test. http://www.sendspace.com/file/hkyhe1 Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted April 14, 2010 Author Contributor Report Share Posted April 14, 2010 Here how it looks in 3DC... same problem as 3.2.09 scale is much bigger but now orientation is also wrong (object is facing the wrong way) Quote Link to comment Share on other sites More sharing options...
Advanced Member michalis Posted April 16, 2010 Advanced Member Report Share Posted April 16, 2010 I have seen this problem too. For one reason blender imports this OK, so I do this first, discard the .mtl and then go to zbrush. I also use the 'set to global space' command every time I resize or move a voxel layer, or after importing an obj there. I'm not sure if this related to this problem though. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted April 16, 2010 Author Contributor Report Share Posted April 16, 2010 No, .mtl file does not hold position and scale info. I just tried in blender and retopo layer and exported voxel object scale and orientation does not match. Also as I posted in the screenshot above orientation and scale are wrong even if I just reimport in 3DCoat as reference mesh. The problem only affect Export Object option and not Export scene. The reason you dont have any problem importing in Blender is probably because one of those 2 reasons maybe you use export scene option instead of export object or that you dont make retopo in 3DC so you dont see how they does not match. If you try with the test files above you will see that it doesnt work. But really, I must thank you tough for the tip about deleting the .mtl because very often I get error notices in Zbrush when trying to import .obj files from 3DC, but when deleting the .mtl it seems I dont get error messages anymore! Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted April 16, 2010 Author Contributor Report Share Posted April 16, 2010 Export Pattern for Merge respect scale and orientation!!! Now I can export both matching retopo and voxel layers.At last. Note:So Andrew,if you want to fix this you must find what is difference between Export Object and Export Pattern for Merge.It will give you the answer about what makes scale and orientation wrong . Quote Link to comment Share on other sites More sharing options...
