YafaRay in Blender
digman
I got YafaRay running inside Blender 2.49 now. I downloaded and rendered some lighting examples so the renderer works but no texture materials are showing up,so off to tutorial land and YafaRay docs to see what I am doing wrong...
YafaRay does great faster rendering. I do really like the lighting in LuxRender though the renders are very slow so I will continue to use it.
When ever I get something that looks good, I will post it...
Edit:
Ok, got the basic textures, I don't think they had the right path to the texutes in the lighting examples. I made my own scene applied the textures and they worked. Now I learning how to light the scene with YafaRay... :moil:
Edit 2:
Normal maps working, at least most of the way...
https://3dcoat.com/forum/index.php?/topic/5699-yafaray-in-blender/
Ok, got the normal map working better, I had made a user error.
I still need to retopo as it is just auto seams on the quadranqulated model of about 10,000 polygons
A first test render of YafaRay with texture and normal maps only
No subdivision, just smoothing in Bender
Rendering time 30 seconds with AA passes set at 3 the other AA settings left at default on an older dual core
Not a wip image just a test render...
https://3dcoat.com/forum/index.php?/topic/5699-yafaray-in-blender/#findComment-42925
I'm not sure if normals worked as they should be. Looks more like bumps. Does yafaray supports tangent normal maps?
IMO, yafaray is an excellent render engine for architectural visualizations. But I prefer to export everything as .3ds to sketchUp and render it there (some nice render engines there)
For renders like this one here , choose internal renderer, its much better. Try the 2.5.2 render branch from 'www.graphicall.org' and have some tests with experimental indirect light option. Soon, we'll have a new engine here. Its a very fast renderer now. For this kind of rendering, expect 10-100 times faster, especially when mirrors, walls and floors exist. My 3DC models took some 10-30 sec to render.
https://3dcoat.com/forum/index.php?/topic/5699-yafaray-in-blender/#findComment-42929
You are right,Michalis YafaRay turned my normal map into a bump map. :(
I was wondering why the extreme angles were looking flatter than I thought they should but just assumed I still wasn't quite understanding the Blender normal map routine...
Downloading 2.5 from the site...
https://3dcoat.com/forum/index.php?/topic/5699-yafaray-in-blender/#findComment-42930
Do not forget to check 'normal' and 'tangent mode' when importing n_maps. Import these to v2.49b and save. Then open in v2.5.2 (check tangent again). If 'save' there, do not open again in 2.49b. This is a warning lol
There are some bugs when importing obj in 2.5.2
https://3dcoat.com/forum/index.php?/topic/5699-yafaray-in-blender/#findComment-42932
