Member RP_Seattle Posted June 11, 2010 Member Report Share Posted June 11, 2010 Not sure how to post this error...but help!?! Win7-64bit, Nvidia fx1500m...vista 64-bit drivers (only ones available for OS) 3DCoat loads and runs but any attempt to switch tabs...Sculpt, Voxels, etc give an error and shuts down: Moderator edited for brevity. I also sent your bug report by email to Andrew at: Support AT 3d-coat DOT com Quote Link to comment Share on other sites More sharing options...
Javis Posted June 11, 2010 Report Share Posted June 11, 2010 Hi! I have shortened your full bug error and sent it to Andrew at support AT 3D-Coat DOT com Quote Link to comment Share on other sites More sharing options...
Member RP_Seattle Posted June 11, 2010 Author Member Report Share Posted June 11, 2010 Thanks so much! I haven't tried running 3DC in a while but dl'd the latest build to try on my XP to 7 converted laptop...and ran into this error...dangit! Again, many thanks! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted June 12, 2010 Report Share Posted June 12, 2010 Thanks so much! I haven't tried running 3DC in a while but dl'd the latest build to try on my XP to 7 converted laptop...and ran into this error...dangit! Again, many thanks! Try to delete file MyDocuments/3D-CoatV3/Options.xml (keep it somewhere before deleting) If it was it then please send me the file to support for analysis. Quote Link to comment Share on other sites More sharing options...
Member RP_Seattle Posted June 13, 2010 Author Member Report Share Posted June 13, 2010 Andrew, I send the files attached, also to support@3d-coat.com. I tried as you suggested but had the same result. When I clicked on Sculpt tab, 3dCoat crashes. The old and new xml files are attached. Thanks, Roger OLD_Options.xml Options.xml Quote Link to comment Share on other sites More sharing options...
