2.02 Final on Download Page?
Yes, 2.02 is done!
The list of features:
1) New unwrapping tool, now it is wery easy to create uv-set for the model
2) Topological symmetry is implemented. You should define two symmetrical faces to define this symmetry. After that you can flip layers with symmetry or copy the layer to the opposite side.
3) LWO files can be used like brushes.
4) 5 types of color pickers are implemented - all of them are movable and resizable
2) Stability improvements, many bugfixes
3) Focal shift slider implemented
4) Flipping sliders on top panel (Focal depth & smooth degree are also there now)
5) Storing last folders
6) Now you can make your own custom fill patterns in Fill tool. They will be applied with cube mapping with soft edges. It allows to make seamless cube mapping
7) Cube mapping improved (in materials menu): preview during texture moving is now very convinient, cube mapping becomes seamless
8) Clone tool and Sculpt tool now uses alpha even if it is not round.
9) 3DB stores window position
10) Drawing performance improved
11) Hue variation is add to color change tool
12) You can pick top layer by pressing 'H'
13) Navigation with pen improved (it was difficult to navigate with pen)
