Andrew Shpagin Posted December 21, 2007 Share Posted December 21, 2007 I have done the new version, 2.02 SP3. It is in beta state, but I think it is stable enough. The link is below: http://www.3d-brush.com/files/3d-brush-2-02-sp3-en.exe The list of changes: 1) FBX import was done. It is important because it saves properly the smoothing groups. 3D-Max <9.0 and Maya are not able to export correct OBJ files with smoothing groups, so FBX import is important for MAX & Maya users. 3DMax 9 is able to export/import correct OBJ files, but not everyone have Max 9.0. 2)The other important feature - ability to export low-poly meshes with original positions of vertices. It is mostly important for users that use Auto-mapping. 3) The pallette window is now resizable and can be closed if necessary. 4) The new important feature - presets window. You can store there full state of pen shape / radius / depth / strip shape / material / filler / color / smooth and restore that settings any time by one click. It can speed up work much. 5) The new navigation bar is implemented, it can be useful for those peoples who use pen. 6) The old annoying bug is fixed - undo in line mode was sometimes incorrect. 7) Some peoples had a problem with input dialog - it also was fixed. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted December 23, 2007 Share Posted December 23, 2007 The new Navi is acting a little strange for me. The rotate moves fine at first but then as I drag it whips around. Same for the pan, it moves normally at first, then suddenly zips across the screen. The zoom seems fine so far. Quote Link to comment Share on other sites More sharing options...
