Contributor artman Posted August 18, 2010 Contributor Report Share Posted August 18, 2010 I want to see if people are able to reproduce before sending file or testing further with other files...Im in a hurry right now. So could please anybody try a simple modification using "edit proj in External editor" and report if changes translate well to 3DCoat? On Windows 3.3.12 Cuda DX 64 preferably. When I save the modified layersZ.psd 3DCoat destroy all layers on return (nm,color,all layers...) Leaving only one layer left which have the applied modification. All layers are collapsed,just like if "merge visible" command was used I tested with PS and Gimp. Thanx. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted August 19, 2010 Author Contributor Report Share Posted August 19, 2010 Can anyone confirm if it works? Im having hell with this right now. Use Edit Projection in External Editor,create a new layer ,save file and check how it looks back in 3DCoat. Quote Link to comment Share on other sites More sharing options...
Advanced Member jacobo Posted August 19, 2010 Advanced Member Report Share Posted August 19, 2010 Can anyone confirm if it works? Im having hell with this right now. Use Edit Projection in External Editor,create a new layer ,save file and check how it looks back in 3DCoat. 3DC x64 CUDA DX 3.1.12 1- Created a Voxel Sphere 2- Retopoed it 3- Sent it to the paint room for pppw/nm 4- Sent the projection to Pshop (CS4-32bit) 5- Saved and alt-tabbed back to 3DC, the modifications appeared Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted August 20, 2010 Report Share Posted August 20, 2010 Yes, found, reproduced and fixed. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted August 20, 2010 Author Contributor Report Share Posted August 20, 2010 Yes, found, reproduced and fixed. Whouhou!! The Bugsquasher strikes again. Thanx Quote Link to comment Share on other sites More sharing options...
