philnolan3d Posted August 29, 2010 Report Share Posted August 29, 2010 This bug has been around for a long time, I really hope it can get fixed. I've seen it with multiple tools before. This time it's the Scrape tool. The pen goes all crazy when it gets near hard edges or even just big lumps. So now the scrape tool is not usable. I've tested all of the other voxel tools and only Scrape is doing it. Video: http://screencast.com/t/OTBkNzA5ZW Edit: Correction, the same Surface tools that did it months ago are doing it now too. Flatten, Chisel, SF. Clay, and Rapid Quote Link to comment Share on other sites More sharing options...
Member debris Posted August 30, 2010 Member Report Share Posted August 30, 2010 Confirmed here... Quote Link to comment Share on other sites More sharing options...
Member martinni Posted August 31, 2010 Member Report Share Posted August 31, 2010 Yes, I have similar issues Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted August 31, 2010 Report Share Posted August 31, 2010 Please send me 3B file because it works well on all my samples. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted August 31, 2010 Contributor Report Share Posted August 31, 2010 Is space uniform? Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted August 31, 2010 Author Report Share Posted August 31, 2010 Sample file sent. Quote Link to comment Share on other sites More sharing options...
Member martinni Posted August 31, 2010 Member Report Share Posted August 31, 2010 Just found a solution! The problem is as Artman suggests, that the volume is not in world space, if you right click the problematic volume and select "move to object space" the problem dissappears Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 1, 2010 Report Share Posted September 1, 2010 Ok, I made that it will work correctly even over non-uniform spaces. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted September 1, 2010 Author Report Share Posted September 1, 2010 Just found a solution! The problem is as Artman suggests, that the volume is not in world space, if you right click the problematic volume and select "move to object space" the problem dissappears This might also solve the problem I was having a lot with the symmetry plane never staying in he middle. Thanks to you and Andrew. Quote Link to comment Share on other sites More sharing options...
