3D-Coat 3.5 updates thread
I re-uploaded Win builds -
- updated manual
- fixed navigation issue
- fixed different undo & LC issues, I was testion a lot, in all combinations it works well now
- Seve to 3B problem fixed
- clone LC-ed model problem solved
Beat Kitano, we almost resolwed your problem with mesh. The reason was in saving separate volume as 3B. In general it is possible to recover, we will add "Weld" command to voxels menu that will finally recover the object.
Hi BeatKitano :)
The mesh explosion is solved now :) we have implemented a new command called LegacyFix (or Weld, Andrew will choose ;)) that basically heal any corrupted information in LC so it make it ready :), I'll make a video soon on how to use it, hope it helps!
using the same test model you sent us:
Without fix
post-5788-0-21704500-1321038686_thumb.jp
After fix: now is fully usable :)
post-5788-0-34005700-1321038739_thumb.jp
[OFFTOPIC] Since Andrew started a new thread about 3.7 updates, maybe we should say goodby to 3.5 updates thread and call it done ?
Absolutely. Done. :)
Please post all update questions, comments, etc. in the new 3.7 updates thread quoted above and posted below. Thanks!
http://3d-coat.com/forum/index.php?showtopic=8887
