Advanced Member vivi Posted October 4, 2010 Advanced Member Report Share Posted October 4, 2010 I have a Toshiba T900 tablet PC which is actually pretty good. i7 M620 @ 2,6Ghz and 4GB RAM, Win7 64bit. I use 3DStudio Max without problems. When I try to convert a Voxel object to paint, at the point where it says "creating mesh " ( sometimes earlier ) it juts freeze. The progress bar says 0% ( not responding) It happens with not so complex objects...pretty sure it can't be due to the resolution. somebody having similar issues?? Vito Quote Link to comment Share on other sites More sharing options...
Psmith Posted October 4, 2010 Report Share Posted October 4, 2010 Vivi: If you can give me a numbered list of steps you took to initiate this crash, I can troubleshoot and maybe pinpoint the problem so Andrew can fix it. Greg Smith Quote Link to comment Share on other sites More sharing options...
Advanced Member vivi Posted October 4, 2010 Author Advanced Member Report Share Posted October 4, 2010 Vivi: If you can give me a numbered list of steps you took to initiate this crash, I can troubleshoot and maybe pinpoint the problem so Andrew can fix it. Greg Smith well..basically i made a tentacle and used the axial tool to make several copies...just about 6. then I just right click on the voxel layer and say retopo for paint. thats it. When creating a mesh it just won'T do anything. IT basically with all objects..unless the voxel resolution is really low. EDIT: it seems low resolution also won'T work Quote Link to comment Share on other sites More sharing options...
Member ron3fp Posted October 11, 2010 Member Report Share Posted October 11, 2010 When I try to convert a Voxel object to paint, at the point where it says "creating mesh " ( sometimes earlier ) it juts freeze. Hi Vito, I'm not sure if the problem I did face corresponds to the behavior that you are experiencing when trying the Auto Retopo to Paint Room, but maybe you want to try NOT to perform AUTOPO with Additional Smoothing of 0. At least for me, whenever I tried to perform AUTOPO with a smoothing of 0, 3D coat would hang. When using a smoothing of 1 or bigger, the auto retopology was performed within minutes - with 0 I could wait for a night without a result and then would have to kill the 3D Coat process. Regards, Ron. Quote Link to comment Share on other sites More sharing options...
Taros Posted October 11, 2010 Report Share Posted October 11, 2010 Why don't you use the support forums for such discussions, please? Quote Link to comment Share on other sites More sharing options...
