Blender Applink
haikalle
5 hours ago, Carlosan said:
Gob addon was moved to upper middle viewport.  What do you think about to move yours to that location ? (without overlapping both, of course)
What is the Gob addonon? Is it a replaceent or update of the Blender Addon?
Gob addon (GoZ-alike tools for simple ZBrush<->Blender interchange.
I rather have the applink where it is now.
On most projects I won't be using the add-on during all stages of the process, and sometimes it won't be used at all. Having a button visible at all times I think it clutters the interface and adds some substantial visual noise. On the other side, opening the tab to the occasional (albeit frequent) transmission of assets between both programs isn't that clunky. I hardly see any organised work needing a frantic constant exchange, even while rapid changes in the process requires frequent back and forth. We work and polish using both programs, but the bulk of the work isn't in the exchange, but inside applications. Maybe other workflows could benefit from the suggested placement above. I couldn't tell.
What about making it optional? Would that be feasible?
I prefer the Blender applink on the Blender N panel as well.
oki
  • 2 weeks later...
Is there anything update on this?
Please let me know if it reproduces or does not.
On 4/27/2020 at 11:27 PM, roentgen said:
thanks @haikalle
I attach the file.
`__staffB` is an object was created by AppLink. UV-sets of this are consolidated to one, and can see/edit on 3d-coat.
'staffB' is an original of '__staffB', has UV-sets can not see/edit on 3d-coat.
staff_b.blend
I decided to give this applink another try with newest addon zip (what I found from this threat) and I can get models to 3DCoat but not back there (there is not any message / Blender doesn't response anyhow).
I also noticed that there is many tutorials that doesn't count anymore with applink (buttons have been taken off ect.)? Is there still coming updates to this applink and when we get updated tutorial?
  • Applink Developer
@platyros Do you have latest 3d-coat version? There has been some issues with applink lately. Micro-verts are not working at the moment and also there is some scaling issue.
But Per-Pixel mode should work OK. I think that I need some extra work with applink before updating tutorials.
Right now applink is in very unstable state...sorry about it.
Edited by haikalle
  • Applink Developer
One reason why it's unstable state is that I made a big changes for the code. The code started to become harder and harder to read so I need to rearrange code better.
This task is not finished yet. My time is limited at the moment so progress is slow but I will let you know here when it's good time to test applink again.
Edited by haikalle
  • 1 month later...
The applink work for me to send objects from blender to coat but not from 3dcoat to blender. I use the latest blender build and latest 3dcoat stable build.  4.9.49 .
I setup my exchange folder and exported inside it my fbx file from coat but blender does not update nor making the shader links with textures.
I also use the 3dc  preset with blender applink.
Anyone know why this is happening?
  • Applink Developer
there is issues with applink right now...not sure yet when I have time to tackle them.
You might try this trick to get it working. I noticed on a few occasions that it helped.:
1) Go to your MYDOCS/APPLINKS/3DCOAT/EXCHANGE folder and delete or move to a separate location, the BLENDER folder.
For some strange reason, the contents of that folder mess up the Applink once in a while.
2) Test a simple export of the default Cube in Blender, to 3DCoat and back
  • Applink Developer
ok. let's make blender applink great again. here is update. but it's early beta. Please report bugs reports only now. Know issue:
-Scaling issue when using voxels
-Microverts mode dosen't work
coat3d.zip
  • Haha 1
coat3d.zip
Funny choice of words. :D
Thanks for the assist. :good:
  • Applink Developer
now micro-verts works
coat3d.zip
Please test this only 2.83 =>
Edited by haikalle
Hi! @haikalle when you write 2.83=> does tha mean 2.83 and up? In essence could it work with 2.9 as well? Thanks for clarifying.
  • Applink Developer
Yes. I have testes it with 2.90 too :)
  • Applink Developer
Question for all applink user. Do you want "GetBack" button back?
Sometimes it's useful, yes.
  • Applink Developer
Now udim is supported more fully with applink. Need to fix one bug in blender before showing videos...
