schwungsau's doodles
schwungsau
  • 2 weeks later...
  • 2 months later...
I love doodles!
A great start of a sketch-book. :clapping:
Last one in modo, did you exported displacements, normal maps, is this a PPP or MV, a workflow is always welcome.
Are you using the latest 501 version?
usely i use "export as lwo" which brings my all the maps etc...pretty simple.... sometimes, in modo, i tweak/paint the colormaps...
the skull is just as obj-hires mesh export (500 poly)-->load into modo--> add shader with noise bumpmap --> press render...
the sculpt of the skull and render it are done in 20 minutes. sometimes, i dont wanna waste time with UV,s etc, just see my ideas in quick rendering...
i am using modo5 of course... ;)
anyway the pumpkin and the eye also rendered in modo. displacment maps, color maps etc done in 3d coat and export lwo into modo.
  • 2 weeks later...
Some cool little doodles here Schwungsau,definately good way to get into 3D Coat,will give you a feel for the tools.
Keep on doodlin' :)
  • 5 months later...
