Advanced Member ghib Posted April 8, 2016 Advanced Member Share Posted April 8, 2016 This does not work with Maya 2016, can anyone else confirm? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-133368 Share on other sites More sharing options...
Styler Posted April 8, 2016 Author Share Posted April 8, 2016 ghib, which os are you using? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-133370 Share on other sites More sharing options...
Advanced Member Hammers Posted May 10, 2016 Advanced Member Share Posted May 10, 2016 I'm having trouble getting this to work. Using Edu version of 2016, plugin shows in plugin manager but gives me: -------------------------------- // Error: line 1: ApplinkError: file /Users/Stephen/Library/Preferences/Autodesk/maya/2016/plug-ins/3dc_applink.py line 57: Registration failed for <coatExport> command. // // Warning: line 1: Failed to call script initialize function // // Error: line 1: (3dc_applink) // I'm on OSX10.9.5 btw Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-134546 Share on other sites More sharing options...
Styler Posted May 10, 2016 Author Share Posted May 10, 2016 Hammers, which version of applink? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-134562 Share on other sites More sharing options...
Advanced Member ghib Posted May 15, 2016 Advanced Member Share Posted May 15, 2016 Hey Styler, for some reason when I updated to the latest 3DCoat version 4.5.38 your script now works. Sorry for any consternation I might've caused I'm on Win7 64Bit Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-134786 Share on other sites More sharing options...
Styler Posted May 15, 2016 Author Share Posted May 15, 2016 i'll check it Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-134815 Share on other sites More sharing options...
Member Justifun Posted May 18, 2016 Member Share Posted May 18, 2016 I keep getting the error - Warning: <Applink> No information for processing import" when i try to press the import button in the maya script maya 2016 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-135049 Share on other sites More sharing options...
Styler Posted May 21, 2016 Author Share Posted May 21, 2016 I keep getting the error - Warning: <Applink> No information for processing import" when i try to press the import button in the maya script Check applink settings. 3dcoat version and exchange folder in "My Documents" must be the equivalent Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-135191 Share on other sites More sharing options...
New Member kayan Posted June 1, 2016 New Member Share Posted June 1, 2016 I do not have a new version of Maya. For this reason I want to download the old version of Maya Applink, it has broken links. I hope that it becomes available old version of Maya Applink. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-135699 Share on other sites More sharing options...
Member Pawel_ Posted June 2, 2016 Member Share Posted June 2, 2016 I just installed 3D-Coat AppLink for Maya. When I hit the button "Load plugin" in Maya I getting an error: loadPlugin("3dc_applink.py"); // pymel.internal.factories : MFnDagNode.model is deprecated // pymel.core : Updating pymel with pre-loaded plugins: DirectConnect, mayaHIK, AbcImport, tiffFloatReader, VectorRender, gpuCache, rotateHelper, Substance, MayaMuscle, AutodeskPacketFile, autoLoader, fbxmaya, matrixNodes, ik2Bsolver, modelingToolkit, OpenEXRLoader, ikSpringSolver, Mayatomr, AbcExport, ArubaTessellator, quatNodes, mayaCharacterization, OneClick, retargeterNodes, sceneAssembly // Warning: pymel.internal.factories : could not create a PyNode for manipulator type nexManip // // Error: line 1: UnicodeDecodeError: file C:\Program Files\Autodesk\Maya2014\bin\python27.zip\json\encoder.py line 384: utf8 // // Warning: line 1: Failed to run file: C:/Program Files/Autodesk/Maya2014/bin/plug-ins/3dc_applink.py // # Error: pymel : Failed to get controlCommand list from 3dc_applink # # Error: pymel : Failed to get modelEditorCommand list from 3dc_applink # # Error: pymel : Failed to get command list from 3dc_applink # # Error: pymel : Failed to get constraintCommand list from 3dc_applink # # Error: pymel.core : Failed to get depend nodes list from 3dc_applink # // Error: line 1: (3dc_applink) // What is the reason for the error? ---- I'm using Maya 2014 SP3. I made install like below: Copy file "3dc_applink.py" from "plug-ins" folder ( depend on Maya version ) to ..\Maya20xx\bin\plug-ins Copy whole folders "icons", "shelves" to ..\My Documents\maya\20xx\prefs Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-135770 Share on other sites More sharing options...
Styler Posted June 3, 2016 Author Share Posted June 3, 2016 Pawel, Can you attach your config file? C:/Users/UserName/Documents/applinkMayaCoat.cfg Kayan Which version are you using? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-135859 Share on other sites More sharing options...
Member Pawel_ Posted June 4, 2016 Member Share Posted June 4, 2016 I'm sending config file. I'm using 3D-Coat 4.5.23. applinkMayaCoat.cfg Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-135880 Share on other sites More sharing options...
New Member kayan Posted June 4, 2016 New Member Share Posted June 4, 2016 I'm using Maya is 2010. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-135887 Share on other sites More sharing options...
Member Pawel_ Posted June 4, 2016 Member Share Posted June 4, 2016 (edited) 4 hours ago, kayan said: I'm using Maya is 2010. So? Do You know what could be the problem? Documentation says "Supported: Maya 2011+ (32/64)". On my friends computers Applink is working with Maya 2014. Edited June 4, 2016 by Pawel_ Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-135906 Share on other sites More sharing options...
Member Pawel_ Posted June 7, 2016 Member Share Posted June 7, 2016 Can anyone help me? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/6886-maya-applink/page/4/#findComment-136027 Share on other sites More sharing options...
