Taros 370 Report post Posted January 4, 2011 Very nice Greg! I really like your voice, it is perfect for training videos! Share this post Link to post Share on other sites
Javis 523 Report post Posted January 4, 2011 Awesome! Congrats in getting these out - I know how painful it is to get these things all recorded, edited, produced, marketed and so on. You've done a very fine job here good sir. Share this post Link to post Share on other sites
shawnlau 0 Report post Posted January 4, 2011 I just saw the new set of beginner tutorials, and wanted to say how much appreciated they are. They do an excellent job in demonstrating the workflow and features without getting lost in nuances and fussing. Very well done. And nice rat, btw Share this post Link to post Share on other sites
Psmith 87 Report post Posted January 5, 2011 Mr. Geo Faust: Thank you for your congratulations. I receive them earnestly, as training brother to training brother. And, it is most heartily appreciated in lieu of your most formidable video legacy. Greg Share this post Link to post Share on other sites
GFX-1 0 Report post Posted January 6, 2011 Will there be a part six to cover painting? Thanks! Share this post Link to post Share on other sites
michalis 129 Report post Posted January 6, 2011 Well I also own groboto and its a cheap and interesting app. Parametric volumes are great and topology is almost excellent. The problem (a serious one) is that you can recognize the groboto style from miles away. Trying to edit these primitives and in most cases retopology is needed again. Your work , psmith, on tutorials is excellent. The missing tutorials. Share this post Link to post Share on other sites
Psmith 87 Report post Posted January 6, 2011 The missing tutorials are coming up, shortly. There have been a few technical issues I wanted to straighten out with Andrew about AUTOPO and painting functionality before leading anybody into it. But, these should be solved soon - and then we can go forward. Michalis: Have you seen the new "smoothing" functions in Groboto 3 - plus all of the boolean functions? It is true, the Groboto "Bot" construction method is visible 10 miles away - but all this new stuff makes it much more generically functional - and allows total originality. Groboto Smoothing Greg Smith Share this post Link to post Share on other sites
Psmith 87 Report post Posted January 7, 2011 Here is Session No. 6 in the "3D-Coat From Scratch" series. It covers AUTOPO for the Rat's Teeth, painting the teeth and exporting them as an .obj file with accompanying textures: Rat's Teeth as an Asset Greg Smith Share this post Link to post Share on other sites
Taros 370 Report post Posted January 7, 2011 A small, but not unimportant tip for video tutors: If you have waiting times, f.e. when the app is calculating something and shows a progress bar, try to use this time to explain something, if needed. But if you have nothing to say, just delete this part of the video. The viewers are not forced to wait for the next tutorial step. Don't show the same steps more then twice. Example: You are using Autopo for several objects by single, show the progress for one or two objects, and delete the video part for the rest, then just say: "Replay this steps for the rest of the scene". This is enough and will be understood by the user. Additionally this makes your tutorial flow easy to follow and the video file size smaller, too. Best wishes Chris Share this post Link to post Share on other sites
Tony Nemo 398 Report post Posted January 7, 2011 A small, but not unimportant tip for video tutors: If you have waiting times, f.e. when the app is calculating something and shows a progress bar, try to use this time to explain something, if needed. But if you have nothing to say, just delete this part of the video. The viewers are not forced to wait for the next tutorial step. Don't show the same steps more then twice. Example: You are using Autopo for several objects by single, show the progress for one or two objects, and delete the video part for the rest, then just say: "Replay this steps for the rest of the scene". This is enough and will be understood by the user. Additionally this makes your tutorial flow easy to follow and the video file size smaller, too. Best wishes Chris IMO, Chris' remarks reflect his expert knowledge, but a real newbie will benefit from the leisurely pace of the narrative and the repetition. Share this post Link to post Share on other sites
michalis 129 Report post Posted January 7, 2011 I agree, to the extent that there are some things I don't particularly like, at times (n-gons and sometimes the loops spiral instead of the algorithm making closed loops). But then, once again, it's not intended to be a replacement for Manual Retopology. It's intended to be a tool to use when precise CONTROL (over topology) isn't completely necessary. The idea of adding guides and painting areas of density is an effort to meet somewhere in the middle...between Total control (manual) and No control (automation). I'm sure Andrew will continue to make some improvements over time. Adding the "Dot-Loop/Ring" feature I mentioned (many times) would help expedite the cleanup phase. +1 I'm wondering though... loops rings and autopo is a fast method to have a more suitable base mesh for surface sculpting (zbrush) What if: we could manually construct topology in some parts and ask autopo to do the rest? Just a thought. Its not similar to just autopo and edit after. Not always as easy as it looks like. BTW abnranger, yes I can export a high density quad mesh but I really don't like it. Rather useless for me. Share this post Link to post Share on other sites
Mykyl 2 Report post Posted January 7, 2011 I actually thought that would be perfect as well. Create topology where you know you can do better then autopo finish it off. However I would say this would be good in addition to the current way of doing it. No idea if its possible of course. Cheers Mike R Share this post Link to post Share on other sites
philnolan3d 253 Report post Posted January 8, 2011 I'd like to suggest that the videos be also posted in the first post so that it's easier to find for those who need to. Share this post Link to post Share on other sites
Psmith 87 Report post Posted January 8, 2011 Phil: Yes, I think this is a good idea. I'll do it. Greg Share this post Link to post Share on other sites
Britain 5 Report post Posted January 8, 2011 This is a great tut. I personally like the delay, it gives me time to reflect in 3DC what was shown. Cant wait for the next session! Thanks V Share this post Link to post Share on other sites
CoolCGI 0 Report post Posted January 8, 2011 Hello, I'm a very new user of 3D-Coat and I wanted to say thanks for posting these tutorials. I just watched the first episode, and I already run into an issue. So I hope you don't mind asking for some advice in this thread (if this is not the appropriate forum section, please feel free to move it). The issue I'm having is when I want to place the sphere for the rat's head. No matter what I do, I always end up with 2 spheres side by side, even when I zoom all the way to align the blue dots (which are red for me btw.) I actually had the same issue with the SNAKE tool for the neck, I did get "double necks" goin all over the place, but somehow managed to get a single one at some time. Thanks in advance for any help on this. Share this post Link to post Share on other sites
AbnRanger 1,537 Report post Posted January 8, 2011 What if: we could manually construct topology in some parts and ask autopo to do the rest? Just a thought. Its not similar to just autopo and edit after. Not always as easy as it looks like. You can do that already...Autopo first, then select poly's you want to redo manually, delete them, and rebuild. Also, the Strokes Tool is like a mini Auto Retopology tool on it's own (that's why early on I suggested Andrew make Autopo essentially the Strokes tool on steroids), as you can draw your guides/strokes and hit enter for it to construct the poly's for you. Share this post Link to post Share on other sites
Psmith 87 Report post Posted January 8, 2011 It is tricky to align those little dots. What I have found to work for placing, first the neck and then the sphere, is to right click, first, right on that line of symmetry, directly where you want the neck to begin, and immediately start brushing upward - it takes practice. For the sphere, right click first, on the line of symmetry, move your cursor straight up - fairly high above the neck, aligning the 2 dots - then left click - this also takes some practice. But, this is not the only way to place a sphere or paint a neck. Try using the "Curves" tool - placing 3 nodes of the right diameter, right on the line of symmetry - pressing "Enter" when you have the shape you want. Use the "Primitives" tool, set to "Transform" in the Tool Panel, and manually align the sphere by means of the widget. You can even turn off "Symmetry across the X axis" for this one action - turning it back on when you are done. Greg Smith Share this post Link to post Share on other sites
3dCoatWannabe 0 Report post Posted March 1, 2011 Greg - VERY cool tutorials!! You have a great voice and a lot of talent for teaching. Really helped me with some basic concepts and brought up features I didn't know existed. I've downloaded all 7 and have one question, that is probably obvious to everyone except for me. How does one get the teeth into the mouth, to use in a program like Lightwave? I didn't see any precise measurements being made, so I'm very curious about how they will fit and work in the final step to get the teeth into the mouth and then setup some morphs or animation to be able to use the teeth? It would be great to see the mouse actually use the animated teeth. Thanks!! Share this post Link to post Share on other sites
Psmith 87 Report post Posted March 2, 2011 Sorry for the late reply. I've been in San Francisco demonstrating 3D-Coat to the Game Developer's Conference crowd. About 30 from the 9 biggest game studios. It went well. So, I am just now reading the forum again. The teeth are just a voxel object like the Rat is a voxel object. In the Voxel Room, use the "Merge" command to add the teeth to their own layer, (Merge works with .3b files - which is what the Teeth are.) While merging, use the Transform widget to position and size the Teeth inside the mouth. Since the Rat and the Teeth are on their own layers, and the Rat already has mesh topology, (through AUTOPO), run the AUTOPO routine on the teeth layer. When finished, they will end up on their own layer in the Retopo Room. From there, use "Merge for per-pixel with NM" from the Retopo menu, (or any other "Merge" command) - and you end up with both the Rat and the Teeth on their own layers in both the Sculpt Room and the Paint Room. Since everything now fits, you can just export both meshes and their corresponding textures in the format of your choice for use in an app that has animation. I'll be getting to that in some future videos. Think about these things - the process is very linear, and applicable to most everything you'll be making in 3D-Coat - for use elsewhere. Hang in there - good things are coming. Greg Smith Share this post Link to post Share on other sites
jaf 3 Report post Posted July 13, 2011 Thank you very much. I've been away from 3D-Coat for a while and now I'm lucky to be back. Great tutorial! Share this post Link to post Share on other sites
mohamedshaban 0 Report post Posted May 15, 2012 thank u very very much great tutorial by great man Share this post Link to post Share on other sites
margaritelsoto 0 Report post Posted September 17, 2012 Excellent piece of work. Keep up the good work. Looking forward to reading more such intriguing stuff. Thanks for sharing ! Share this post Link to post Share on other sites
shedman1983 8 Report post Posted October 18, 2012 Nice tutorials Share this post Link to post Share on other sites
Mwalker8028 0 Report post Posted November 19, 2012 So Ive been learning a lot from all the videos u post and this is what i came up with. and i was wondering when would be the right time to dress the model and how would i go about doing that. right now all i have is the voxel shape and im a little rusty at retopology right now but im currently watching the pirate tutorial. Any resource the shows how to retop a whole body? or should i go with my gut? Sorry i have so many questions, im a mega noob at this, just trying to get some help. well if i can figure out how to post the picture i will show u Share this post Link to post Share on other sites
